Squeaky rear right brake??
maxwolfie
Postby maxwolfie » Fri Jan 20, 2006 12:19 pm
Hey, all
My back right brake is squeaking pretty bad when I brake, or use the handbrake.... Particularly a whole lot worse when its raining or when brakes are cold ?? After about 15-20 minutes of driving it is silent..
Squeaking frequency is directly proportional to the revolutions of the wheel....
I'll explain this is noise-speak as if I'm slowing down in the morning to take a corner :mrgreen:
squeak squeak squeak sqqueaak squueakkk SQUUEEAAAAAKK SQQQQQQQUEEEAAAK (as in the squeaks get louder and longer (more drawn out if you know what i mean) as my car comes to a complete stop
Ideas? Thinking a part of the rotor is glazed.. or something.. dont know much about brakes
Ideas? Definately back right wheel
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
ndragun
Postby ndragun » Fri Jan 20, 2006 12:35 pm
the rears are probably just getting down to the wear markers...
1994 MX5 Clubman
XIDAs, Wilwoods, 6ULs
maxwolfie
Postby maxwolfie » Fri Jan 20, 2006 12:36 pm
My mech checked out my brakes about 4 weeks ago and he said they were all almost brand new
'89 JDM NA6 (black)
ndragun
Postby ndragun » Fri Jan 20, 2006 12:47 pm
unlucky...
some other alternatives then
- foreign object embedded in your pad - that will burn its way out eventually.
- pads have small locator sheaves that can occassionaly work themselves loose and start pushing against the disk... I can't remember if they actually have these in the rear - but in the front at least - i had one work its way out on the drivers front, which made painful noises. This would typically only happen if you've installed new pads fairly recently though. They tend to seat themselves in place fairly strongly after a bit of heat and dust has a chance to stick them down.
just take the rear wheel off and have a look around at any rate... they're fairly simple things to diagnose.
1994 MX5 Clubman
maxwolfie
Postby maxwolfie » Fri Jan 20, 2006 12:53 pm
Sweet, yeah I must admit I havent been bothered to take off the wheel, after all it goes away, will check for obvious problems this arvo
'89 JDM NA6 (black)
npn4875
Postby npn4875 » Fri Jan 20, 2006 2:39 pm
I had that in the SP - turned out to be tiny stones trapped in the caliper.
Mike
Every k over is propaganda
Black SP
sabretooth
Postby sabretooth » Fri Jan 20, 2006 5:36 pm
Check for any crap in the calipers and pads, and also apply some anti-squeal compound to the rears of the pads.
Users browsing this forum: No registered users and 200 guests
