Fire Extingisher Mount
irwin83r
Postby irwin83r » Wed Jan 04, 2006 8:32 pm
if its just a sheet of stainless like the one in the pic i can make them.
anyone have a drawing or able to pull one apart and give me some detailed photos and measurements?
price will depend on mat costs. i'll go to the stealstore and see if i can get trade rates through my firm, if welding is needed i have access to mig, tig and stick but am not a certified welder, and am not a gun welder... so i would rather dodge welding if we can.
irwin83r
Postby irwin83r » Sun Jan 15, 2006 10:38 am
yeah thats what i thought. but somone mentioned some thing about welding..
i dunno, thats why i was wondering if anyone had a pic of one in bits
Ted
Postby Ted » Mon Jan 16, 2006 10:43 am
Haven't looked at the NC, but both the NA and NB need the bottle to sit a bit further forward of the seat frame mounting points. Then there is the matter of the slight rise in the floorpan at this point, and you need to get it as low as possible so that the seat can still slide over the bottle for any shorter drivers etc.
Never considered using plate, wouldn't be that cheap I imagine.
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
irwin83r
Postby irwin83r » Thu Jan 19, 2006 5:52 pm
would there be any problems with just using the seat hold down bolts. putting a thin piece of plate between the floor and the seat wouldnt make the seat sit much differently.. and i cant imagine it effecting the safety rateing of the seat mounting
Red Baron
Postby Red Baron » Tue Jan 24, 2006 6:44 pm
For less than 30 bucks go down to Bunnings, buy a sheet of alloy plate, about 1.5mm checker alloy, you will also need a couple of longer bolts to replace the bolts from the seat. Cut to any shape you like as long as it fits under the seat runners and will take the extinguisher bracket and you have it.
The benefit with thin alloy is that you can force the shape to the floor and when bolted down it will take the shape of the runners.
My exthinguisher sits about 100mm forward so you get full movemnet of the seat and it really does not get in the way for passengers. No probs with scruitineers.
really no point being precious, who looks at the floor anyway.
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
Red Baron
Postby Red Baron » Fri Jan 27, 2006 5:58 pm
With mine I needed another 5mm, not enough thread holding for my liking. If yours are ok then no problem
baron
Red
JBT
Postby JBT » Thu Feb 09, 2006 5:51 pm
I just made a firex mounting for the passenger's side (driver's side is wider) from 3mm steel plate. Gawd it was hard to get hold of a small bit of plate without buying a truckload :shock: :evil:
Anyway, finally got a bit cut to my dimensions (roughly I might add) by a small welding shop. I drilled all the holes and painted it matt black. It is very unobtrusive and probably wouldn't even be noticed by 9 out of 10 people. If you don't have the gear to drill holes 12mm holes in steel, make a cardboard template and get the steel man to drill them and your firex mounting bracket holes as well.
This set up only allows about 100mm forward travel of the seat without unclipping the fire extinguisher, but my pax seat has been fully rearward since the car was bought 3 years ago, except to vacuum behind it :roll: .
Here are some pics.......yes the front of the seat runners look like they need some paint and the car needs a bit of a vacuum - bloody flash :evil:
green_comet
Car Detailing Guru
Postby green_comet » Thu Feb 09, 2006 8:33 pm
I might be able to get some made up if people are interested.... I am already getting Radiator panels made.
http://www.aus-cartalk.com/viewtopic.php?t=16966
So these fire extinguisher mounts should be no worries at all...
irwin83r
Postby irwin83r » Mon Feb 13, 2006 11:26 pm
thanks JBT and others something to do next weekend if i dont get the exhaust wrap :D
TonyMax
Postby TonyMax » Fri Jun 22, 2012 6:46 pm
JBT wrote:Anyway, finally got a bit cut to my dimensions (roughly I might add) by a small welding shop. I drilled all the holes and painted it matt black. It is very unobtrusive and probably wouldn't even be noticed by 9 out of 10 people. If you don't have the gear to drill holes 12mm holes in steel, make a cardboard template and get the steel man to drill them and your firex mounting bracket holes as well.
Big ups to you for putting up these pics particularly the measurements, we now have one exactly the same in the passenger side of my wife's car ready for Phillip Island next weekend.
~the artist formerly known as MizMac~
Re: Fire Extingisher Mount
Postby manga_blue » Fri Jun 22, 2012 8:24 pm
CAMS regs for the fastening from the fire extinguisher bracket to the mounting plate specify steel bolts. Here's part of AROCA's scrutineers check sheet for a Vic club day:
AROCA wrote:Check Mounting Bracket
Mounting bracket is metal with at least one metal strap
Mounting bracket, strap and over centre clip is not damaged.
Mounting bracket is secured using minimum of 2 Grade-6 or greater bolts of a minimum 6mm diameter and self locking nuts.
A suitable sized body washer may be required to provide extra support for the bracket.
The securing system must be able to withstand a 25g deceleration.
Rivets or self tappers won't get you through the scrutineers in the Vic events any more. Actually they shouldn't be allowed through anywhere. A loose fire extinguisher is a very lethal weapon.
JBT
Postby JBT » Fri Jun 22, 2012 9:59 pm
No rivets or self tappers used in the mounting system I described above. :?
Postby manga_blue » Fri Jun 22, 2012 10:39 pm
JBT wrote:No rivets or self tappers used in the mounting system I described above. :?
No, others were mentioning rivets. Just thought it worth broadcasting.
greenMachine
Postby greenMachine » Fri Jun 22, 2012 11:47 pm
Wouldn't be the first, for sure. The rent-a-racer that I crewed on for the WP 300 used pop rivets :shock: , loose pop rivets at that :shock: :shock: , but it was mounted up high on the parcel shelf, so on impact the whole thing - extinguisher and bracket - would just take off and go straight through the windscreen :shock: :shock: :shock: . That was fixed PDQ.
:mrgreen:
Postby Regie » Sat Jun 23, 2012 2:18 pm
JBT, was the bracket made for your NC?
Return to “MX5 Motor Sport”
