Has anyone used this on their NA6?I bought them to try it on my Na6 turbo that I'm putting together,would it make much difference on a turbo car or are these made for Na motors?any info would be great.these have a 8.78lift on them.
Thanks
HKS 264 degree cams
- PASHN8
Would make a good difference with a decent sized turbo and boost. I believe the best combo is a 264/272 combo for the street.
What sort of boost are you going to run?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
cams
Okibi,Still fixing some side intrusion bars in my Legacy at the moment,so don't have time tonight but I will go to one of your meetings,Thanks.
Pashn8
I'm going to be running a Tdo5 16G turbo and I'm planning to run about 10-12psi.got the wiring harness for the Haltech made up,so it won't be long now then we can see how much boost it can take.
Pashn8
- PASHN8
Trust TD05 or a Mitsubishi TD05?
- 2005 MX-5 SE
- PASHN8
Trust/GReddy, same company
I take it its internal gated? what flange is that? WRX TDO5?
- 2005 MX-5 SE
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
- Sean
Okibi wrote:If you don't end up putting those cam's in, i know someone in WA looking for a set.
http://www.aus-cartalk.com/viewtopic.php?t=26208
