hello all,
can someone post or send me pics of the mania sub frame braces fitted on their car, I'm pretty sure i know where they go, but i just want ot be 100% sure, the front goes on the holes already present in the shock towers and will need to bent a little to tighten right up, and the rear is the linked one and will need a re-alignment done on the back wheels, unless i use a 4 post hoist and mark the bolts before i release the tension,
hope this is right, sorry for the essay!
JR
- emecksphive
- emecksphive
- emecksphive
- smiles
For the rear I didn't raise the car just undid the nuts and place the bar on. It was a snug fit as you can see in the pic the ends of the bar touch the rail lips but it bolted on fine. Visually I couldn't notice any change on the bolts regarding alignment but I'll be getting the alignment done soon anyway as the car needed it.
What grade Tae Kwon Do are you, I got up to red belt and then got distracted by girls ... this was years back!
- emecksphive
- PASHN8
Whats the rear one worth to buy? I have a RobbieRat H-brace under the front.
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
