why would u say its a give to someone else job?
to remove the soft top do you have to destroy the seal at the base of the soft top?
where can u drill holes though?
irwin83r wrote:to remove the soft top do you have to destroy the seal at the base of the soft top?
irwin83r wrote:wow, you done all of this side winder??
im not sure if i want to go wuiet that far. but thanks loads! will look into this "Kit" from the states for the soft top.
but im tempted to remove it and leave it out. in any case i wont be doing this stuff till i hit the tracks more regularly.
oh and what the hell are baby teeth??
if i remove tow hooks should i install an aftermarket front and rear tow point for track?
