brake rotor sizes??
- randymx5
brake rotor sizes??
how many different rotor sizes are there? and inturn how many different calipar sizes are there (you would think there would be the same..
NA1.6 rotor diameter 235mm
NB1.8 rotor diameter 255mm
1.8 titanniuma and SP turbo 270mm
calipars?? NB1.8 and SP turbo compatibale????
thinking of a 'cheap' brake upgrade..LOL
R&ALL
RED 1990 MX5, AVO stage II, 148.5rwKw
- hot rod
Re: brake rotor sizes??
randymx5 wrote:how many different rotor sizes are there? and inturn how many different calipar sizes are there (you would think there would be the same..
I'm looking at upgrading my NA brakes aswell. they're possibly some of the worst brakes I've ever experienced lol...
I already have 15-inch wheels so the SP 270mm discs should fit but is this a conmon conversion? I want to change the discs and calipers.
DBA also sell the SP brakes in the 4000 1-piece series.
- Boyracer
- MX-5 Encyclopedia
- CT
hot rod wrote:randymx5 wrote:how many different rotor sizes are there? and inturn how many different calipar sizes are there (you would think there would be the same..
You may want to check the master cylinder and prop valves too. They are different between the NA without ABS and the NB with ABS. Prop valves are not used on the NB8B and SP/SE because of electronic EDB so you may also need to add brake proportioning.
The NA 1.8 brakes are the simplest upgrade because it bolts on without requiring any hydraulic changes. You might be better off rebuilding your current calipers (I'd do it to 2nd hand ones anyway), upgrading lines to stainless, using a good fluid (Motul RBF600 for eg) and using a higher spec pad. You will be amazed at how good stocky brakes can be.
- irwin83r
- CT
My point is not one of actually having done it but rather one of, just check this won't be an issue. In the NB8B, SP and SE, the front to rear proportioning of the brakes are handled by the ECU. They call this electronic distribution of brakeforce (EDB) or similar. In earlier model cars, this was done by the hydraulic proportioning valve that sits adjacent to the master cylinder in the engine bay. My point is that by changing the brakes hardware, you are altering the front to rear balance. If it's in your ECU, it should be able to deal with it. If it's hydraulic, it might be changed enough to worsen your braking - I don't know.
Check out this pic I have borrowed from safetymans beautiful beast.
http://img424.imageshack.us/my.php?image=enginepic28ih.jpg
The silver thing with lines going into it on the right of the master cylinder, is a hydraulic prop valve. So there you go, it's hydraulic. So, for a road legal car you can fit an adjustable one in the engine bay and have it secured so it can't more. For a race car, it must be within fingers reach so you can alter it based on conditions, ie in the wet give more to the rear. BUT, if the piston size of the calipers is unchanged, you will only slightly change the bias so you might be able to correct it with different spec pads front vs rear. If the piston size is different, then you might need a prop valve. I use a wilwood one in the race car.
http://www.wilwood.com/Products/006-MasterCylinders/001-PV/index.asp
If the master cylinder sizes are different things could also go awry. I think NB8B is 15/16 - it's on the top of the MC under the reservior so check yours and see what you've got. Hopefully the same but it could be 7/8ths. Can't remember.
STOP PRESS: ABS and EDB appear to be controlled by a seperate ABS module in the NB8B and not the main ECU. I need a wiring diagram to confirm but so far haven't found one. Off to the big forum...
- Matty
CT, the prop valve is different between NA6, NA8 and NB8, with the system getting more rear bias each time.
The NB8B/ABS cars use a straight-through fitting that could be replaced by a prop valve, though I have heard of some people adding this fitting to a non-ABS car without problem (ie without rear lockup issues)
I fitted an NB8A prop valve (pn NC10-43-900A) to my car, and noticed a definite improvement. The Wilwood/Tilton would probably be cheaper though...
and yes, when fitting bigger rotors you need new caliper brackets at the minimum. (and pads.)
- Russellb
- RIP Nov 2014
CT the ABS has its own computer I know from the Wiring Diagram i have.
As for th ecomputer Bias control I have found no Evidence of one (you can pull the ABS fuse or remove the ABS completely and the Brake Bias dosn't change )
if you would like a wiring Diagram for the 2000 NB Drop me an Email and I'll send you a copy 8MB in total
- CT
Russellb wrote:CT the ABS has its own computer I know from the Wiring Diagram i have.
Hi Russellb - I'd love that wiring diagram if at all possible to split the file into smaller chunks. But, the ABS ecu does control the EDB which started on 10th month 2000 cars. This is the NB8B and I can assure you the biasing does radically change if you pull the fuse on a car with EDB. NB8A cars from 98 to mid 00 use a seperate prop valve (as seen in the pic from my earlier post) which is why I think you have the earlier NB's wiring diagram. Not sure how the EDB works though, surely it must have a gyro or something???
Matty, yeah funny how the cars have been getting progressively rear biased to a point where it needs EDB to keep it braking in a straight line. I have a wilwood on the race car and it's excellent but from our current tinkering with NB8Bs, there appears to be no reason to disable the EDB and ABS. I suspect however that if the new Porker GT3 has no fancy brake gizmos, then the simple NB8B might be able to survive without them as well.
- Matty
CT wrote:Matty, yeah funny how the cars have been getting progressively rear biased to a point where it needs EDB to keep it braking in a straight line.)
EBD isn't a bandaid, it's a better system giving optimal braking force under all conditions. That it allows more rear bias under light force is much better for wet/low grip conditions.
Though I have no logical explanation for the excessive front bias in the early cars...
- CT
- Boyracer
- MX-5 Encyclopedia
- RobbieRat
Users browsing this forum: No registered users and 122 guests
