Mounting 4 point harness
smiles
Postby smiles » Wed Dec 28, 2005 11:30 pm
I've got a 4 point harness that I use in my other car, I've replaced the drivers seatbelt bolts with eye bolts and the same on the rear passengers and can just clip the harness in easily for track days.
Can something similar be done on an mx5 (NA6)?
Is there somewhere to mount an eye bolt on the rear shelf?
What's the easiest way of mounting a harness on the car?
CT
Postby CT » Thu Dec 29, 2005 9:57 am
Get a brown davis half cage with mounting points. It'll protect your head as well as your body. Highly recommended if you intend to use the 4 pt harness for track work.
Matty
Postby Matty » Thu Dec 29, 2005 5:03 pm
CT is right - don't use a harness without a roll bar.
The lower seatbelt mounts can be replaced by the eye bolts, like you did previously. On my car, I made up some sleeves that mimic the shoulder on the OEM bolts, allows the seatbelt to stay in and pivot freely.
Slugoid
Postby Slugoid » Thu Nov 02, 2006 2:14 am
Sorry about digging up this old thread.
Just wondering, is there ways to mount a 4-point harness without a roll bar?? Can the NA8 seat belt brace do the trick?? I really can't afford a roll bar or the brown davis half cage at this point in time :(
rain902
Postby rain902 » Thu Nov 02, 2006 5:27 pm
Slugoid wrote:Sorry about digging up this old thread.
if you must, get out your 7/16" drill bit and your 10mm spanner/socket and lift the carpet on your back deck - at the very back of the deck it angles upwards, the panel there is double thickness. Punch two holes as indicated and dont forget to use reinforcing plates like these shown. Make sure you have most of the afternoon free to mess with removal and reinstallation of the carpet, and in hindsight I woulda removed the seat to allow easy access to the back deck.
I looked @ the seat belt brace and decided that it would be too high to be effective or even safe I think.
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
MEXFIVE
Postby MEXFIVE » Thu Nov 02, 2006 7:35 pm
is it possible to fit harnessess with standard seats in the car with a roll bar like this, it has to eye on it behind each seat
rain902
***COW***
Postby rain902 » Thu Nov 02, 2006 8:06 pm
erm - yes it is, but that is not a roll bar, its a style bar - roll bars are designed to prevent the occupants from being crushed in the event of a rollover, style bars are designed to look cool, not save the occupant in the event of a rollever :shock:
Slugoid
Postby Slugoid » Thu Nov 02, 2006 10:57 pm
Thanks for the info and pics rain :) I knew the only real option was a few holes in the rear deck, but was unsure if it was safe just to drill holes there.
Btw, have you had any problems with the scrutineers on track? How strict are they on mounting points and how secure it is?
Matty
Postby Matty » Thu Nov 02, 2006 11:06 pm
rain IS a scrutineer... :lol:
Andy Wana
Postby Andy Wana » Thu Nov 02, 2006 11:18 pm
Does this count as a roll bar? (Pardon the newbie question)
I ♥ asymmetry
rain902
Postby rain902 » Thu Nov 02, 2006 11:55 pm
Slugoid wrote:Thanks for the info and pics rain :) I knew the only real option was a few holes in the rear deck, but was unsure if it was safe just to drill holes there.
thanks Matty :)
All scrutineers have differing opinions however I think that due to my own personal hates my idea of harnesses is pretty harsh - if it gets past me then it should get past anyone. If a scrut knocks you back, you can ask to see the chief scrut and point out to them that the material there is above the crease line, fluted and double thickness. (on an NA it is anyways) Suggest that the material further down is single layer and less substantial - upon second examination they may decide that it is pretty good after all.
I am viciously strict on harnesses helmets and roll cages in that order. I would pass my car with the harness installed where it is, but if they were installed 30cm further forward, in the single layer sheetmetal that bolts on over and around the fuel tank then I would not pass it.
The cams manual requires the reinforcing plates to prevent pull through but is strangely silent on the requirements for location of the holes save for schedule I (3)(b) which states that it must be to a substantial part of the vehicles structure, reinforced (like in the pics) or to the rollcage (see pic below)
My rationale for passing a harness mounted as depicted is "if i hit hard enough for me to worry about tearing out the mounts, thats the least of my problems" :shock: :shock:
Just for bragging rights, this pic was taken 5 minutes ago in my garage - this is how i really love my harness to be mounted - can't wait to see you all this weekend! :D :D :D
Slugoid
Postby Slugoid » Fri Nov 03, 2006 12:51 am
Matty wrote:rain IS a scrutineer... :lol:
Haha, silly me :P
Well I guess if a scrutineer says it's ok, then I'll go ahead with the harness purchase and installation. AS 2596-1983 standard, so it should be good. Then I have to get a "3mm steel plate of at least 75mm X 50mm" (Schedule I 3a). Better safe than sorry :)
Hopefully I'll see you in the future rain. Might be going to the PI on Dec 17 :mrgreen:
rain902
Postby rain902 » Fri Nov 03, 2006 3:21 am
Haha, silly me :P
i'll be there with bells on :lol: :lol: love to see you there for the istate challenge :D :D
revvo sells the backing plates already made - the dimensions arent exactly the same, but the surface area works out i think. they are about $6 each, beats cutting, bashing and welding if you ask me...
Slugoid
Postby Slugoid » Fri Nov 03, 2006 10:57 am
rain902 wrote:revvo sells the backing plates already made - the dimensions arent exactly the same, but the surface area works out i think. they are about $6 each, beats cutting, bashing and welding if you ask me...
Where abouts is revvo? Or you mean Revolution Racegear :?:
Btw, the "Phillip Island 1hr" is this weekend right? Didn't get info about it from the mx5 club but maybe i wasn't looking the the right place :P
rain902
Postby rain902 » Fri Nov 03, 2006 12:21 pm
yah revolution @ mitcham.
dunno whats on @ PI this weekend - most of us are off to winton for the 6 hour event - 2x mx5 teams competing :lol: :lol: :lol:
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 108 guests
