Perspex as the rear window in NA???
PT
Postby PT » Fri Dec 16, 2005 9:30 am
Hi guys,
We've pulled a display down at work and I have this 2.5x3.5m sheet of perspex.
Reckon I could cut it up and have it stiched and glued in as a rear window in my NA? I know the NB's have fixed glass but have a different way of folding down.
I would obviously unzip to fold down, but would it work?
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Rasco
Postby Rasco » Fri Dec 16, 2005 10:13 am
what a great idea - has anyone tried?
I wonder how it would fit - the rear window on the NA needs to bend a bit when you fold it down - plus y'd have to be careful putting the roof down in case it broke the perspex
you'd be able to use all different colours - I've used some perspex as a wind blocker but reflection was really harsh fyi
Philip Lee
Postby Philip Lee » Fri Dec 16, 2005 10:24 am
i think Zoom (japanese shop) has a similar product and i guess it should work fine.
MVZOOM
Location: Road signs are so hard to read when you are driving quickly....
Postby MVZOOM » Fri Dec 16, 2005 4:11 pm
Wouldn't perspex scratch a little easily?
Cheers = Mike
'97 LE [R.I.P] - 240kW Mazda3 MPS, BMW E46 M3, Lotus Exige S
PT
Postby PT » Fri Dec 16, 2005 4:18 pm
Probably no worse than the plastic in there.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Me
Postby Me » Fri Dec 16, 2005 5:32 pm
i had though of that before. But how do u seal the softtop technically?
Philip Lee
Postby Philip Lee » Fri Dec 16, 2005 6:09 pm
hot glue?
PT
Postby PT » Fri Dec 16, 2005 6:40 pm
Yeah, stitch it and glue it.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
ndragun
Postby ndragun » Mon Dec 19, 2005 9:29 am
Believe it or not, the NB top folds down exactly the same way as the NA.
The only difference between the two frames is a small spring attached to the third frame member, the one just up behind your head...
1994 MX5 Clubman
XIDAs, Wilwoods, 6ULs
Roderic
Postby Roderic » Mon Dec 19, 2005 4:47 pm
Yeh cant see why it wouldnt work....would be the same concept as the NA Tops which come with glass in them. Yeh you would just unzip before lowering.
ndragun
Postby ndragun » Mon Dec 19, 2005 4:54 pm
Roderic wrote:Yeh cant see why it wouldnt work....would be the same concept as the NA Tops which come with glass in them. Yeh you would just unzip before lowering.
You don't even have to unzip before lowering if its done properly...
1994 MX5 Clubman
kitkat
Postby kitkat » Wed Dec 21, 2005 6:32 pm
perspex would work well but what would be better is polycarbonate plastic (i think thats it anyway)
Its only bout 2mm thick but it alot stronger from what ive been told.
What im trying to say is if something come flying at your back window (dunno what and how but yeh) polycarb wont break whereas perspex will.
Definatly a good idea though!
adamjp
Postby adamjp » Wed Dec 21, 2005 9:41 pm
My understanding is that PolyCarbonate is also more scratch resistant.
PT - Keep us informed, I like the sound of what you are proposing.
Adam
PT
Postby PT » Wed Dec 21, 2005 11:54 pm
Guys, this project is off as I got my SE today with glass rear window, and brisbanites want some perspex to continue my work, its yours.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
rain902
Postby rain902 » Thu Jan 12, 2006 2:53 pm
perspex isnt going to be legal as it doesnt shatter the same as safety glass...
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
Users browsing this forum: Google [Bot] and 38 guests
