Most powerful road rego'd MX5 in Oz? NSW car with 357hp?
Sean
Postby Sean » Thu Nov 24, 2005 8:59 pm
Back to the old debate about who has the biggest dyno sheet.
Claims of 357hp, with a custom plenum, exhaust manifold, cam gears, BIG turbo this could well be the car to beat if Dyno racing is your thing?
It's also been out to WSID and I belive also runs in the 12s
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... Track=true
AJ
Postby AJ » Thu Nov 24, 2005 9:11 pm
starting bid of 40 GRAND???? :shock: :shock: :shock:
XMX5 Rogues
JBT
Postby JBT » Thu Nov 24, 2005 11:09 pm
AJ wrote:starting bid of 40 GRAND???? :shock: :shock: :shock:
Tell 'im he's dreamin' :P
kula
Postby kula » Thu Nov 24, 2005 11:49 pm
that 13B one would beat it for power.
chuck will soon as well.
lowmiata
Postby lowmiata » Fri Nov 25, 2005 6:43 am
kula wrote:that 13B one would beat it for power.
got to run a mazda mx5 block and head (B6 or BP) for it to be classed as an mx5!
13b mx5s aren't in the same catagory!
EVI15 1998 to 2008
kula
Postby kula » Fri Nov 25, 2005 9:14 am
that one on ebay doesnt fit then, looks like an MX6 engine?
4sfed5
Vehicle: NA6 - Turbo
Postby 4sfed5 » Fri Nov 25, 2005 12:47 pm
Just caught up with a local club member whos put a mazda 323GTR (yes GTR) engine and turbo in, running off microtech engine management. results from the first tuning session netted 195 RWKW. :D
Interesting to see how power goes when the boost goes up from stock!!!!
Sean
Postby Sean » Fri Nov 25, 2005 5:37 pm
Car above has run 11.5 so far with lots of wheelspin.
I could be wrong but I thought it was a stroked and bored BP?
tsmithy
Postby tsmithy » Fri Nov 25, 2005 6:06 pm
Thats a beautifull custom plenum, what a car!!
How did he get a 2235CC? I though the max was 1995cc via flyin miata stroker kit? Any ideas? To go custom must have cost big $$$ ??
Its even got the gear box conversion!! WOW
Give me this over a brand new NC anytime :)
RobbieRat
Postby RobbieRat » Fri Nov 25, 2005 7:42 pm
That engine is a stroked Mazda FE3, its a JDM, which we or the States didn't get.
Getting that capacity is easy, you just bolt in the 2.2ltr crank into the 2.0ltr Fe3.
Unfortunatly we only got the SOHC version as in the early 626's.
Cheers Rob
Sean
Postby Sean » Sun Nov 27, 2005 6:31 pm
Ah OK thanks for clearing that up.
Sean
Postby Sean » Thu Oct 05, 2006 8:12 pm
I think chuck has canned the engine plans for his mx5...
Postby Okibi » Fri Oct 06, 2006 12:12 am
This listing (4592094396) has been removed or is no longer available. Please make sure you entered the right item number. :(
StanTheMan
Postby StanTheMan » Fri Oct 06, 2006 8:37 am
Okibi wrote:This listing (4592094396) has been removed or is no longer available. Please make sure you entered the right item number. :(
Original post was in 2005 :mrgreen:
Postby Okibi » Fri Oct 06, 2006 9:06 am
Ahh I think I remember that car!
