How to care for the softop roof??
Hi all,
Now the sun is shinny brightly in Sydney, I was wondering if anyone knew of a product to put on the softop to protect it from the sun, and prevent cracking and fading??
Anyone found whatever you use attracts dust??
A saleperson once told me that he thought there was a product especially for this purpose - but he couldnt remember the name of it!!
Thanks
Fleery
Thanks
Fleery
Point of advice...Don't use Amourall. Makes the top greasy and attracts dirt. I use 303 Aerospace protectant. It leaves a nice sheen, makes the top nice and black and is also a UV protectant.
I think others have tried Autoglym and Meguiars products, but i cant comment on them since i have never used them. Both products are supposed to be pretty good though.
Hope that helps!
Hope that helps!
- Mr_Q
Re: How to care for the softop roof??
fleery wrote:Now the sun is shinny brightly in Sydney ...
Looks like we found another solution ... just have it rain non-stop.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
- KIJIMA
- CT
We've been through this a number of times before but the OEM soft top is UV protected from factory and only requires cleaning with a soft brush and light detergent to keep it clean. The best is the meguiars citris based vinyl/leather interior cleaner. Use of protectants on vinyl can cause the oil based lubricants that form the synthetic fabric to break down and harden causing premature wear. If you speak with guys that repair dashboards, they will tell you the only safe cleaner to use on a dash is a mild detergent and water - for exactly the same reasons. Protectants dry out the surface promoting cracking not protecting it.
well its catch 22 isn't it. If you don't use protectant, after a while, like all UV protectants that have been applied from the factory, they eventually 'lose' its protection through natural breakdown from the harsh UV and solar rays. If you do use protectant, you need to keep using it otherwise like CT said, it will dry up and cause cracking. So whats my point?! I forgot. no seriously, the point is if you dont use, it will fade/crack/deteriorate etc but if you do use, you must use religiously ie. after every wash.
My 2 cents worth
My 2 cents worth
- CT
fleery wrote:Vinyl breaking down?.....sounds like a sales pitch to me. The dash/roof will crack without any protectant on it. The 303 specifically specifies use on vinyl soft top roofs...anyway, whatever, each to their own; at least it doesnt look dull and faded from the sun anymore!
Enjoy
Fleery
A sales pitch for soapy water? Yeah right. I actually spoke with Mazda when I purchased my first 5.
Users browsing this forum: No registered users and 71 guests
