All the Options
Posted: Tue Apr 12, 2016 11:30 am
by oztrackdays
So I was reading that the MX5 is the new 1934 Ford there are that many engine swap options.
Here are some of the known ones, lets finish the list, will need to get a mod to edit this first post and make it sticky.
http://www.drivermod.ca/articles-1/2016/3/29/miata-engine-swaps Very Big List many silly ones listed.
If we could get a RHD Right Hand Drive Centric discussion going here, that will be helpful.
MAZDA
13B-REW
13B-MSP
BP
MZR 2.0
MZR 2.3
MZR 2.5
SKYACTIV
FORD
Mustang V6 4.0
5.0 Litre V8 older ones (non Coyote)
CHEVROLET
V8 LS1,LS2,LS3,L98,L76 there are more ... http://v8roadsters.com/
V6 LFX,LFW,LF1 there are more ... http://v8roadsters.com/
ECOTEC 2.4 Turbo https://www.facebook.com/Ecotecmiata/
http://www.drivermod.ca/articles-1/2016/3/30/the-ecotec-miata-swap-is-the-bargain-of-the-century
NISSAN
SR20DET
HONDA
K-Series http://kmiata.com
J-Series http://www.superfastmiatas.com/PRODUCTS.html
Please Post BUILD Threads or Articles and any helpful information you may have.
Re: All the Options
Posted: Tue Apr 12, 2016 2:01 pm
by david_syd_au
Won't this list be model dependent, ie NA, NB, NC, ND ?
I suspect you are focused on the NA and NB models.
Re: All the Options
Posted: Tue Apr 12, 2016 3:26 pm
by Nevyn72
TOYOTA / LEXUS
V8 - 1UZFE
http://clubroadster.net/vb_forum/89-roa ... miata.html
Still looking for the thread where someone started doing a Maserati V8 with a transaxle...... :shock:
Re: All the Options
Posted: Tue Apr 12, 2016 4:14 pm
by zossy1
Re: All the Options
Posted: Tue Apr 12, 2016 5:24 pm
by hks_kansei
Pretty sure there’s one out there with a Jag V12
http://jalopnik.com/5112347/v12-miata-a ... -sexuality
And in the USA there’s one with a pair of V8s mounted
http://jalopnik.com/5884363/this-is-wha ... looks-like
Not to mention the multiple electrical conversions to the MX5 over the years.
http://www.zeva.com.au/Projects/MX5/
Re: All the Options
Posted: Tue Apr 12, 2016 5:39 pm
by bruce
You could almost assume everything has been tried!
The two copy Bullets had a 20B and a 2JZ fitted (but they were ICVs).
I've seen a photo in a jap magazine of a GTR RB26DETT fitted (a very tight squeeze).
Re: All the Options
Posted: Tue Apr 12, 2016 5:59 pm
by hks_kansei
I guess it also depends on how much MX5 needs to be left to classify it as an "mx5"
ie: would a full tube frame chassis with an MX5 body on top be an "mx5"?
would an exocet be an MX5?
would an NA chassis with custom subframes at each end be an MX5?
All the MX5/MIATA
Posted: Tue Apr 12, 2016 6:27 pm
by oztrackdays
Good Point on the Chassis Variations, this is rapidly becoming a Spreadsheet will make one at the end of thread and link to that.
NA - RHD
NA - LHD
NB - RHD
NB - LHD
NC - RHD
NC - LHD
ND - RHD
ND - LHD
Space Frame Derivations, also Included but they are able to make structural changes and have
no power/displacement to weight limitations.
I guess the other points are
Wet Sump/Dry Sump ?
Power Steering Delete Needed (Yes/No)
Mazda OEM Gearbox Retained (Yes/No)
Re: All the Options
Posted: Tue May 10, 2016 11:29 pm
by Alex 2550
Check this out for change the undies moment in a Rb26 powered NA....... Insane!!
https://m.youtube.com/watch?v=ww7oGKkrU-0
Re: All the Options
Posted: Wed Jun 08, 2016 11:53 am
by speed
I thought about doing this. A VW VR6 conversion.
http://forum.miata.net/vb/showthread.php?t=444363
Re: All the Options
Posted: Fri Jun 24, 2016 9:46 am
by Boyracer
Having been for a ride in a NB fitted with a worked LS3 the MX5 chassis does the job very well.
Re: All the Options
Posted: Sun Oct 01, 2017 11:38 pm
by celicapain
Personally I like the idea of throwing a mzfe series out of a camry into a NB. you can get 3-4 liters(depending on var), all alloy toyota stoutness. it would fit pretty easy(LOL), all the tough parts regarding going from transverse to north south have been sorted by people putting them into ae86's. All kind of pointless though, you can enough power out of BP, unless your drag racing in which case your just going to throw some flavor of small block in it anyway.
Re: All the Options
Posted: Mon Oct 02, 2017 7:21 pm
by manga_blue
Has anyone mentioned Cummins diesel yet?
