Robbo's Clubbie Racer
Moderators: timk, Stu, -alex, zombie
- beavis
- Vehicle: NB8B - Turbo
Re: Robbo's Clubbie Racer
It isn't required to run the car.
- Vehicle: MX5 Locost
beavis wrote:It isn't required to run the car.
So just to confirm the detent is not required for the operation of the gearbox?
Oh, and thanks for the shift boots Beavis, received
The gearbox neutral switch is one of the inputs for the ECU to determine idle speed. I think that's its only function.
manga_blue wrote:The gearbox neutral switch is one of the inputs for the ECU to determine idle speed. I think that's its only function.
after some research I gathered I should leave that one alone. Cheers Manga Blue
As far as I can tell the ECU uses neutral switch, clutch switch, TPS closed switch and ECT output to work out whether it needs to idle and how fast it should idle. 3 out of the 4 working seems to be enough though.
A little update on progress
chassis painted, great milestone, no more fabrication = Cleaner shed
floor fitted
removable panel for servicing
floor fitted
Looking good!
- bruce
- Vehicle: NA8 - Turbo
bruce wrote:Looks great.
93_Clubman wrote:Looking good!
Cheers guys, this is good time of the build when you start to bolt together shiny clean stuff.
A little update for the people who like photos
adjustable defuser
engine going in for the last time (i hope)
made up some hydraulic lines
adjustable defuser
Clubbie looks great, as does your shed!
we have some paint, moving in the right direction
- bigdog
- King of the kennel
GR124 wrote:we have some paint, moving in the right direction
Love it!
This is mine:
- greenMachine
Geeze Bigdog, get the front of those guards down
. Those things have the aero characteristics of a brick, but you have made them worse still
Otherwise, I love it, especially the polished aluminium!
That single hoop probably dates the car somewhat, I doubt that it would pass muster as a new build?
Bigdog, she looks like a historic job? looks very well presented. what's powering her?
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
