Designed for 4,5 or 6 point harnesses
Roll bar exceeds SCCA/NASA/FIA/MSA specs for cars up to 2500 pounds
Unbroken driver diagonal and harness bar
Extra front and rear downtubes for improved rigidity
DOMEX 700 MC steel harness mount points
Bauer -
Moderators: timk, Stu, -alex, zombie
Schedule I from Cams manual - won't be required for your open wheeler. However a number of them racing out there do use nets, for obvious reasons. All fixed roof cars are required to have nets, whether using windows or not, per the Cams specs.project.r.racing wrote:most of the time, if you can stick or arm/s outside the chassis, then you need nets.
there is a few glassless/pillarless race cars out there that compete under cams rules. do they need nets? if not, then same should apply right?
project.r.racing wrote:so sounds like we just need the first one built before anything happens.
guessing if you want the sport, but later on in the cars life, you wanted the full race cage. you could just buy the pre fabed tube lengths and weld/add them on?
thanks for all the into so far.
Exocet Australia wrote:Trying not to give too much away but...
Boyracer wrote:Looking like I will be getting the race version in the first shipment, have been thinking about some sort of kit car for a long time and have never really liked the donor part, this came along and I reckon it's just about perfect, Matt also said the first 5 orders get a car trailer included...
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
