This is what ours look like
Moderators: timk, Stu, -alex, zombie
Caffeine wrote:Started rebuilding the SolidWorks model of the car, based on discussions and ideas for impreovements we had with Bigdog on the weekend.
Now that we've decided to go with an NC as the donor car I'll be adding a simple, visually approximate but dimensionally accurate model of the NC drivetrain and suspension to the solidworks assembly, and adjusting the chassis to suit the NC hardpoints (i.e. engine / gearbox / diff mounts, suspension pick up points etc)
Has anyone got an NC they don't mind me disassembling to measure stuff?![]()
what fun this is!
FMS01 wrote:I would give some consideration to extra bracing, there's a few non-triangular areas in your chassis model.
FMS01 wrote:PS. Caffeine, what weight does solidworks give you for the chassis? Ours with the CAMS rollbar and all the bracketry was 98kg before the paint went on.
Boost wrote:hey Caffeine, I noticed that you are drawing the members as lines and then getting SW to convert them to RHS. I never knew SW had such a feature?
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
