If so what filter do you use in it?
Begi Air Intake Filter
- Roadrunner
- coyotes after you
Does anyone here run the Begi turbo intake filter box on their SE?
MeepMeep
- greenMachine
Re: Begi Air Intake Filter
I have a Unifilter in my modified Nitrodann filter box. Pretty sure there is a photo in my build thread. It is more or less the same configuration as yours.
- Roadrunner
- coyotes after you
I have a NitroDann box. Wanting to move away from the unifilter due to it constantly sucking filter oil into the intake piping. Only small amounts but I don’t want the sticky tacky oil anywhere near the turbo impeller. Even happens with the brand new pre oiled filter I got off unifilter. It also rubs the seam join on the body which started to wear a hole in the original one.
There’s a monstrous amount of different K&N filters and the website isn’t that great (hate websites that only search by your car model). Figured if a particular model k&n fits in the Begi box, it’ll give me an idea of what models/dimensions to look at to fit.
MeepMeep
- greenMachine
I have not noticed that, I going to have a look in my piping to see if that shows up - I may end up following suit.
It is certainly a cautionary tale for ensuring only minimum oil remains on/in the filter after re-oiling. Presumably the problem is a result of high air velocity through the filter medium, in which case fitting the largest filter practicable would help by spreading that volume of air over the larger area.
- ManiacLachy
- Engaged
I had a Uni on my Nitrodann intake, when I checked it some years back it was soaked in oil. I swapped it for a K&N which worked well.
Now on my Kraken setup with an intake fabbed up by Daffy's man Daz, I believe running a K&N here too, or similar, inside the reused ND airbox.
- KevGoat
I've used both K&N and Uni in mine and had the same oil problems with the Uni. The K&N supplied with my Begi kit was massive, but it seemed to do a good job.
Sent from my SM-G781B using Tapatalk
- bruce
- Vehicle: NA8 - Turbo
I had the same problems with a Unifilter. You can reduce the amount of oil by sitting the filter on a pile of newspaper for a few days, it sucks/drains the excess oil out.
The US K&N website lists a few hundred different filters.
- Roadrunner
- coyotes after you
KevGoat wrote:I've used both K&N and Uni in mine and had the same oil problems with the Uni. The K&N supplied with my Begi kit was massive, but it seemed to do a good job.
Ohh I didn’t think of an oval shaped filter. That would get more surface area too. I was only thinking cone shaped due to the rising angle of the inner guard.
Do you know the model number of that K&N filter?
MeepMeep
- KevGoat
Not offhand, but I'll take a look as soon as I get a free moment this arvo
- KevGoat
- Roadrunner
- coyotes after you
- greenMachine
greenMachine wrote:I have not noticed that, I going to have a look in my piping to see if that shows up - I may end up following suit.
All I have here is the coldside IC plumbing, no sign of oil there. It may not (yet) have made it through that far though, so further investigation to follow when I next visit Mania.
Having said that, the inlet side and the compressor to IC will need some mods at the very least, maybe a new bigger air cleaner element would be a smart move anyway, oil or no oil.
I wish it were possible to do a cowl intake, improved sound and more room but routing is the problem.
- Roadrunner
- coyotes after you
This is the amount of oil I get in the pipe between the air box and turbo inlet (inlet pipe is welded to the turbo) after 1000 or so Kms.
And it’s not blowby as it’s not connected to the intake pipe.
MeepMeep
- Roadrunner
- coyotes after you
Right so this is starting to fall into the "can I be bothered" basket.
The NitroDann intake uses 2.5in pipe and its kinda crammed right up in the back corner of the air box. This means the widest filter I can fit is 115mm absolute maximum. This rules out the RU-1500 even with a 2.5 to 2.75 adaptor as it's way too wide, possibly too long as well.
Length is also an issue. Because the airbox goes further back (almost hard against the strut brace riser) the guard at this point inside the box is much higher than where the filter is in the Begi box. Because of this the A/C hard line is smack in the middle of the height of the filter mount and with the raised seam on the guard means 100mm long, maaaybe up to 120mm long might just fit but it would need to taper down to 100mm O.D on the top to not rub the seam, so it's something I'd need to test fit first before buying.
Using the K&N filter size search, seems the filters are either 100mm or 150mm long. I'm halfway in between to suit the space.
There there's flow / surface area. The Unifilter filters from the top as well, but the K&Ns are pleated so technically more surface area around the outside?? Don't want to cause a flow restriction going a smaller filter...
A bit more measuring and thought required. Maybe I'll get some cardboard and make myself some fake filters to see what will fit. Or maybe I'll put the lid back on and not look down the intake pipe again.
MeepMeep
