Hey guys,
Anyone come up with a solution for the turbo oil drain back to the sump? Anyone have dimensions?
Would something like this work for the oil pan?
https://www.boostedperformanceparts.com.au/products/oil-drain-adaptors?variant=7854484029468
Would the same part work for the the turbo side too?
SE Turbo Oil Drain
- ManiacLachy
- Engaged
Re: SE Turbo Oil Drain
Are you talking about a replacement for the OEM turbo oil drain (that is known to crack easily if removed)?
I remember someone on the old Mazdaspeed Miata forum did a group buy of them a few years back, I'm not sure what details are in there but there might be some dimensions? Other than that I don't know of an on the shelf solution. You might need to measure the dimensions yourself and fabricate.
But as a hail-mary, check MiataRoadster, they have all sorts of replacement parts and this might be one? You pay for it, but it would be the easy button if it exists.
I don't mind cobbling up something as I'd like to also future proof myself for when I actually replace the turbo/manifold.
I was more hoping someone had easy access to a SE pan so they could give me the spacing between the bolt holes on the oil pan.
