Hey Guys,
does anyone have any kind of manual that has instructions on how you take apart and put together the original airbox intake setup on an NB SE?
I have a haynes manual but it doesn't have the SE and to be honest, isn't as good as what I remember Haynes manuals to be!
Brad
SE Engine bay
Re: SE Engine bay
All/most of the MazdaSpeed manuals are at the following: https://drive.google.com/drive/folders/ ... 0xSNGVXMzA
- Luke
Re: SE Engine bay
I pulled mine apart a few years back when I required access to the Turbo to install a boost controller.
There is really not much to it.
Its just Bolts, clamps, pipes and plastic junk.
As far as I remember.
Unplug intake temp sensor and MAF connector and unclip cabling from the air box. Remove vacuum pipe from air box to turbo pipe, remove air box to turbo pipe, remove top lid off the airbox, take out air filter, unbolt lower parts of air box, pull it out and your pretty much done.
DO the opposite to put it back together.
If you are also talking about removing the lower part of the intake pipe/coupler to the turbo and the outlet side, its just more clamps and pipes to pull out.
I heard a lot of people say it was super difficult to pull those rubber couplings out without breaking them, but I got mine off very easily a few years ago when I needed access to the manifold bolts as mine started loosening after many years of track work.
2022 BRZ 10AE
2021 GR Yaris
2021 GR Yaris
Re: SE Engine bay
93_Clubman wrote:All/most of the MazdaSpeed manuals are at the following: https://drive.google.com/drive/folders/ ... 0xSNGVXMzA
+10000000000000000000000000000000000000000000000000000000000000000000000000
"Do yourself a favour" and save all these files onto a local hard drive because one day they may disappear.
Re: SE Engine bay
Lokiel wrote:93_Clubman wrote:All/most of the MazdaSpeed manuals are at the following: https://drive.google.com/drive/folders/ ... 0xSNGVXMzA
Yeah, archived them offline a while back just in case.
Re: SE Engine bay
cheers guys - I reckon that's the one!
- beavis
- Vehicle: NB8B - Turbo
Re: SE Engine bay
Lokiel wrote:"Do yourself a favour" and save all these files onto a local hard drive because one day they may disappear.
It's OK, that's my link, as long as I'm alive they will stay available. :-)
Users browsing this forum: No registered users and 17 guests
