NB SE Turbosmart kompact plumb back BOV installation question
Posted: Sun Jul 21, 2019 11:52 pm
by crazypsychosydney
Can some one advise whether the Kompact BOV installed incorrectly?
Thanks!
Re: NB SE Turbosmart kompact plumb back BOV installation question
Posted: Mon Jul 22, 2019 8:34 am
by greenMachine
I think not. I think that is the same as recently installed on my car. Going from memory, the inlet is at one end of the cylinder, the outlet on the side. Are there arrows moulded into the body? I'd check on my car but it is inaccessible right now, but hopefully there will be other replies, confirming or correcting my memory.
Posted: Mon Jul 22, 2019 8:42 am
by The American
The vacuum port on the top (bottom of picture) suggests the inlet is on the side and outlet on the bottom (top of picture). So that looks right to me (I don’t have this specific valve, but a similar one).
What I can’t see is the vacuum line to the intake manifold. Is that connected? It won’t work without that.
Posted: Mon Jul 22, 2019 9:17 am
by ManiacLachy
I agree with GM.
I just went through my old photos looking for a shot of my BOV, rather than walk 200m down to look at the car in person! It's the same model, but it's in a different orientation. The long end goes into the intake manifold, the T section heads back to the air intake.
Different throttle body elbow setup to OPs. The hose back to the air intake snakes down under.
Posted: Mon Jul 22, 2019 10:28 am
by Nevyn72
GM & Lachy are correct, high pressure pushes towards the base of the internal piston and against the internal spring.
It's the same on my SE.
Posted: Mon Jul 22, 2019 11:38 am
by bruce
Plumbed to vent into the airbox which is not quite right (should be back into inlet). But if you wan't the loud 'whooosh' that's what you do.
Posted: Mon Jul 22, 2019 12:01 pm
by ManiacLachy
Not necessarily, he's MAF-less, so it doesn't need to be metered and accounted for. Though it probably does make more wooshes this way than not.
Posted: Mon Jul 22, 2019 12:06 pm
by bruce
Cool.
Posted: Mon Jul 22, 2019 3:49 pm
by Eunos_Frogster
Should be swapped around. Looks like the outlet port is going to the charge pipe and the inlet port going to the airbox
Posted: Mon Jul 22, 2019 4:52 pm
by bruce
I wonder how it would drive as technically when the throttle closes all the charge air would be trapped and forced back against the turbo (maybe causing the turbo to stall). BUT there is a school of thought that BOVs aren't necessary (in low boost applications?)
It would be interesting to drive it as is (effectively no working BOV) and then drive it with the BOV in the correct orientation.
Posted: Tue Jul 23, 2019 12:16 am
I guess the BOV 2 pipe should turn around !
Posted: Tue Jul 23, 2019 12:19 am
greenMachine wrote:I think not. I think that is the same as recently installed on my car. Going from memory, the inlet is at one end of the cylinder, the outlet on the side. Are there arrows moulded into the body? I'd check on my car but it is inaccessible right now, but hopefully there will be other replies, confirming or correcting my memory.
Posted: Sat Aug 19, 2023 7:35 pm
by dzzb
This seems to work for me.
