Wastgate actuator question
speed
Postby speed » Tue Jan 08, 2019 7:56 pm
Hey guys, turbo question for the gurus.
I've got a t28 from a s15 Silvia on my NA6 and recently did a motor swap. Car is not boosting as it should. I dont have a boost gauge but it just feels funky and more like an N/A.
Reckon my wastgate actuator was damaged during the motor swap. The o ring on the actuator rod was hanging out and I had to adjust the rod a few turns so I could clip it on the flap.
Would there be any harm in me swapping the t28 wastgate actuator for the one I have on a spare Nissan t25???
I mean is there even any difference?
Thanks!!!Image
Sent from my SM-G960F using Tapatalk
speed
Re: Wastgate actuator question
Postby speed » Tue Jan 08, 2019 8:33 pm
Never mind. Believe I've not put enough preload where the rod clips to the flap.
Will adjust and try again!
Wolfgang
Postby Wolfgang » Tue Jan 08, 2019 8:39 pm
I'm no turbo expert, but a quick google says bolt pattern is different.
speed
Postby speed » Tue Jan 08, 2019 8:42 pm
My bracket has holes for both as I made it that way. Anyways reckon it's my bad for not having adequate tension.
Thank you very much though
Postby Magpie » Tue Jan 08, 2019 9:05 pm
Lokiel?
speed
Postby speed » Tue Jan 08, 2019 9:12 pm
Magpie wrote:Lokiel?
Thanks Mark. Pretty sure it's my fault. I dont even have half a hole preload, so will start with that and see if my boost returns.
Special thanks to Chris Whittaker for talking me thru it. Absolute legend of a bloke!
ManiacLachy
Engaged
Postby ManiacLachy » Wed Jan 09, 2019 7:53 am
You might not have a boost gauge, but you've got a megasquirt, right? So just log it and see what boost you're hitting and at what RPM. Looks like you've found the issue, but you can still check your boost response and level.
