SP BOV Direction/ T-Piece mod
Posted: Sun Sep 02, 2018 10:56 pm
I've heard it mentioned before that some of the SP BOVs were installed the wrong way around. While looking on carsales I found that some of the recent listings do in fact have the BOV the opposite way around.
So my question is - does anyone know what the correct intention for the BOV direction? From my understanding you can run the BOV in either direction but they will change the way it works (one way will act as a progressive safety valve, the other as a switch). https://www.youtube.com/watch?v=lI9rJoNzNVc
This ties into the T-Piece mod.
The T-Piece mod as I understand it, basically ups the boost by 2-3PSI by moving the reference point for the waste gate actuator closer to the valves. Depending on which way the BOV is it will have two possible effects:
1) Lifting off the throttle will be extremely harsh as the vacuum actuates the BOV and you suddenly got from 8PSI to vacuum
2) You have more progressive boost pressure but ultimately lose boost as it is wasted by the BOV opening progressively
Neither is really 'wrong' but the original intended use would matter...
This comment http://mx5cartalk.com/forum/viewtopic.p ... 83#p553291 seems to imply that the ECU was tuned for a higher boost than what the cars were originally shipped with - I was wondering if anyone could provide any more information on that? I find that a bit suspect because this dyno run of the T-Piece mod http://mx5cartalk.com/forum/viewtopic.php?f=43&t=20505 seems to show that the engine is running quite lean.
I don't know a lot about this stuff, so if anyone can clarify anything or correct me I would really appreciate it!
