ECU location SP
roshmx5
ECU location SP
Postby roshmx5 » Wed Feb 28, 2018 7:48 pm
Hi members
Where is the ECU on the SP. is it the grey plastic box in the passenger footwell.
Mazda MX5 SP
Re: ECU location SP
Postby NitroDann » Wed Feb 28, 2018 8:31 pm
Yes mate.
greenMachine
Re: ECU location SP
Postby greenMachine » Wed Feb 28, 2018 9:16 pm
I don't think so. Maybe the SP was different to the NB8B, but in the NB8B it is an aluminium box, under an aluminium cover, on the firewall under the carpet almost at floor level. If the passenger rests their feet against the sloped 'firewall', they will be resting on the ECU cover.
To get to the ECU, lift the carpet, which gives access to the cover - this has to be removed to access the ECU.
I think you are looking up behind the glovebox, that is the HVAC stuff.
Again, I stand to be corrected if the SP ECU was relocated from the standard NB8B configuration.
:mrgreen:
Locutus
Re: ECU location SP
Postby Locutus » Wed Feb 28, 2018 9:56 pm
I think Dann misread the question. The SP ECU is in the OEM location location as described above. I'm pretty sure all the covers are steel- they are far too heavy to be aluminium.
Re: ECU location SP
Postby NitroDann » Wed Feb 28, 2018 11:47 pm
I figured the plastic bit was simply mistaken.
Its a grey box in the passenger footwell for sure.
wasp47
Re: ECU location SP
Postby wasp47 » Thu Mar 01, 2018 2:52 pm
Watch your fingers, the covers bite
roshmx5
Re: ECU location SP
Postby roshmx5 » Thu Mar 01, 2018 3:38 pm
Thanks everyone much appreciated
Mazda MX5 SP
Red_Bullet
Vehicle: NA8 - Supercharged
Re: ECU location SP
Postby Red_Bullet » Sun Mar 18, 2018 9:00 pm
wasp47 wrote:Watch your fingers, the covers bite
I can vouch for that, wear gloves. Then once you have it out remove the burs with a file.
Users browsing this forum: No registered users and 67 guests
