SE ECU anti-tamper nuts
Posted: Mon Oct 23, 2017 6:50 pm
by greenMachine
Just went to have sticky at my ECU - no can do, two of the five nuts holding the cover panel are conical anti-tamper nuts
How do people get these off? Is it possible to get them off without damaging the stud? I guess I could grind the whole thing off, or cut the panel, but if there is a trick I'd prefer to not mutilate things. Tried search, but that didn't do it for me.
I have tried my vicegrips, but they show no sign of moving it, Mazda may have used a thread locker as well
Re: SE ECU anti-tamper nuts
Posted: Mon Oct 23, 2017 6:54 pm
by KevGoat
I ground mine off. Real PITA.
Posted: Mon Oct 23, 2017 7:02 pm
by StillIC
What about a hammer and centre punch, and tap it out (by tapping anticlockwise around the axis)?
Posted: Mon Oct 23, 2017 8:51 pm
by KevGoat
Maybe if can get enough purchase, or dremel a couple of straight/flat sides to fit a spanner or socket (angle may not allow spanner). I can recall they were awkward to get at so I just took the easy way out ...
Posted: Mon Oct 23, 2017 10:27 pm
by Lokiel
Ground mine off too - I think that's the most common way to do it.
Posted: Mon Oct 23, 2017 11:54 pm
by NitroDann
8-10 MM drill bit and ream it on hard until the head is drilled off. Very easy with a powerful battery drill and sharp drill bit.
Posted: Tue Oct 24, 2017 6:36 am
by greenMachine
Thanks all. I think I'll give StillIC's idea a go, and if that doesn't work I'll get brutal!
Posted: Tue Oct 24, 2017 7:02 am
by wasp47
WARNING WARNING The edges of the cover are very sharp, be careful of your finger
Posted: Tue Oct 24, 2017 10:23 am
by Lokiel
wasp47 wrote:WARNING WARNING The edges of the cover are very sharp, be careful of your finger
+1
I've had mine on and off multiple times and got a very deep cut ONCE - I learned the hard way and now always handle it with utmost care.
