oil restrictor ...
tang0_au
oil restrictor ...
Postby tang0_au » Mon Jul 24, 2017 11:17 am
brains trust: is there a formula or recommendation for what size oil restrictor to use in a chinabay GT 2760 (i think) floating bearing turbo ?
Re: oil restrictor ...
Postby NitroDann » Mon Jul 24, 2017 11:30 am
Just use the head feed port with no restrictor.
itll be sweet.
Postby NitroDann » Mon Jul 24, 2017 11:31 am
itll be sweet.
Todd77
Postby Todd77 » Mon Jul 24, 2017 12:31 pm
1.6 mm
Postby NitroDann » Mon Jul 24, 2017 12:47 pm
NitroDann wrote:Just use the head feed port with no restrictor.
itll be sweet. just like sp
Todd77
Postby Todd77 » Mon Jul 24, 2017 1:32 pm
It's just how I set them up, they only need a mist of oil, flooding the bearing can cause slowed boost response ( grab a roller bearing spin it dry, then flood it with oil and spin it.... ) plus there is no need to loose oil pressure thru the turbo. It's not needed. $3 restrictor. But that's just me. I'm no expert!!!
Postby NitroDann » Mon Jul 24, 2017 5:18 pm
I meant to edit the first one to add "just like SP". Not repost over you todd.
I agree nothing wrong with that.
Todd77
Postby Todd77 » Mon Jul 24, 2017 6:55 pm
NitroDann wrote:I meant to edit the first one to add "just like SP". Not repost over you todd.
Are you saying we agree on something! :o :D
tang0_au
Postby tang0_au » Tue Jul 25, 2017 2:18 pm
thanks ...
I already have everything hooked up to the port on the block next to the flywheel - have made up a 1.5mm restrictor that should flow enough ..
