Nissan T28 turbo housing markings
Postby bruce » Fri Jul 14, 2017 5:13 pm
Howdy,
I've searched the interwebs and all I find is conflicting information and a lot of arguing between Nissan fanboys.
Currently have an SR20DET with a T28. Markings on housing read;
Garrett, AR60, M24, 1.1
Looking at a replacement turbo with the same markings but end in a 1.2
Both are supposed to be S14 turbos. Latter described as a S14/s15.
Can't look at the serial numbers for a definitive answer.
What is the difference?
Is it a direct bolt on changeover for my current setup?
Thanks
Bruce
smy0003
Re: Nissan T28 turbo housing markings
Postby smy0003 » Fri Jul 14, 2017 7:02 pm
I think I remember seeing a t25 wastegate (the smaller one) on your car?
The T28 from the sylvias are actually a 2560 turbo, so actually not a T28 at all. The 'T25' is a 2554 turbo. Very confusing.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Postby bruce » Fri Jul 14, 2017 7:49 pm
Hmmm. The mystery deepens.
beavis
Postby beavis » Fri Jul 14, 2017 10:05 pm
As far as I was aware they were pretty much all the same although JDM Silvias got a ball bearing turbo?
I asked my best source of silvia knowledge, his only suggestion was maybe one is journal bearing versus ball bearing?
smy0003
Postby smy0003 » Fri Jul 14, 2017 10:40 pm
S13 engines definitely came with the smaller turbo (2554, smaller wastegate actuator). S14/S15 came with the 2560 which is identified by the larger wastegate actuator.
Postby bruce » Fri Jul 14, 2017 10:51 pm
OK.
I've been told mine is a T28. The 1.1 and 1.2 could be what Beavis said.
Postby bruce » Sat Jul 15, 2017 12:14 pm
I wonder if Dan has any knowledge regards this?
