Hi just wanted some suggestions about alternator bracket
Since I've gone turbo I've had to replace it a few times because it brakes or fractures.
Wanted to know if anyone else has had this issue and if there is a way to fix it cheers
Breaking alternator bracket turbo na
- NitroDann
Re: Breaking alternator bracket turbo na
Do you have photos?
Sure do here's a couple that shows what's happening
- NitroDann
I cant see, is it hosted elsewhere?
Nope can try send them through messenger if you like
Hi mate, you could try using a heim joint adjustable tensioner as i did above.
Available from Aeroflow in different lengths such as part no.# AF60-4000 or AF60-4007. Not sure of the part number for the one i have though.
I had to ream out one of the rod end eyelets a little to fit the bolt that attaches to the mounting tang on the water pump but otherwise it works very well for my application.
Re: RE: Re: Breaking alternator bracket turbo na
3gress wrote:
Holy crap. Dan, your engine looks amazing!
