SP owners T Piece Mod WARNING
- roshmx5
Hi members
If you have done the t piece mod check your boost via a boost gauge.
Mine was spiking to 15psi sitting around 10psi.
Went back to original set up, no spiking maximum boost is 8psi.
Mazda MX5 SP
Re: SP owners T Piece Mod WARNING
Hi Would someone mind explaining the T mod
Steven
Steven
- Black_Penguin
The stock setup has the wastegate reference boost just after the compressor, the T-piece mod has you reference boost just before the throttle so the drop in pressure caused by the intercooler is no longer there.
Sent from my Pixel using Tapatalk
- roshmx5
Here is some info
Mazda MX5 SP
15 year old car with multiple owners, & probably multiple workshops, so it's possible minor changes have been made that haven't been communicated or have been long forgotten.
- Daz
Wow, something else is going on surely !
Back when they were new, some owners had their original short hose between the turbo and actuator melt causing the actuator to do nothing and a corresponding boost frenzy. These served as a warning to the rest of us ! Is the hose used in the mod clear and referencing manifold correctly ? Could also be the actuator, but I assumed you returned to stock and its functioning fine ?
Silver SP - PSS9, 1:10:58
- roshmx5
Acctuator is fine tested it with air compressor. Happy to keep the way it is set up to stock. Car runs smoother
Mazda MX5 SP
- Tezzax5
If your still running the plastic BOV. Check that out as well as you need to treat them as a consumable service item.
When they get a bit of wear on them the diaphragm inside can get a little notchy.
- roshmx5
Cheers Tezza. I have two BOV. One stock and the other off a Porsche. I might upgrade to a metal one
Mazda MX5 SP
- Daz
Tezzax5 wrote:If your still running the plastic BOV. Check that out as well as you need to treat them as a consumable service item.
I am still running the original, cant say I have really notice any degradation, but the car is still has < 45k.
Where do you get them Tezza ? Is there are part number ?
- Tezzax5
Hi Daz long time no online chats...
Bosch BOV Bosch BOV 0280142103 2301020740 is the one you want.
Danny and boys at Automotive + got my last one for me but that was a ages ago....
Tried the $2 mod and hated it, Tried the turbosmart bov , spring that came with was too soft (flutter drove me crazy).
Went back to the plastic bosch and happy enough with it for the sort of driving that i do.
- Daz
Yeah I dont get on here much, check in from time to time !
I have one of those turbosmart BOV's in a box somewhere, never fitted. The car seems fine to me, but I dont drive it much. I remember people saying they smoothed the part throttle jerk a little by replacing the BOV but I never thought it was that bad in mine... they all seemed to be just a little different !
- roshmx5
Just an update guys was at mechanics today. My boost gauge should have been connected at throttle body not manifold. Put T piece back in and full boost is 7-8psi. No spiking.
Mazda MX5 SP
roshmx5 wrote:I had to take T Mod off. ... Bit disappointed as loved the gain from the T piece mod.
Good stuff - disappointed no more!
- roshmx5
Yeah happy much more responsive, last weeks drive without the T piece mod was ok but no where near as good as the run when I had the mod.
Mazda MX5 SP
