Sp owners with Boost Gauge
Posted: Sat Mar 11, 2017 5:29 pm
by roshmx5
Hi members
Have hooked a boost gauge up and plumbed it straight into the manifold. I have done the t piece mod. My gauge sometimes goes up to 14psi as I am accelerating, especially in lower gears first and second.
Is this normal and have I connected boost gauge to the correct place to get a reading.
Have attached pictures
Re: Sp owners with Boost Gauge
Posted: Sat Mar 11, 2017 5:43 pm
by NitroDann
You're going to have a bent rod or missing ring lands, Id take it easy if I were you.
Posted: Sat Mar 11, 2017 5:47 pm
by roshmx5
Thanks Dan so the gauge is hooked up in the right spot, so something is spiking my boost.
Posted: Sat Mar 11, 2017 6:33 pm
by smy0003
Agreed with Dann. Remove the MBC and check boost readings.
Instead of winding up the boost with the MBC, consider looking into ECU replacements to run more boost, more safety.
Posted: Sat Mar 11, 2017 6:44 pm
by roshmx5
I don't have a MBC only the t piece mod. And people say it may give you a 2 psi increase.
Posted: Sat Mar 11, 2017 6:59 pm
by smy0003
Whatever it is, remove and check boost levels on your stock set-up.
Posted: Sat Mar 11, 2017 7:15 pm
by roshmx5
Ok will look into it cheers.
Posted: Sun Mar 12, 2017 10:55 am
by Nevyn72
roshmx5 wrote:Thanks Dan so the gauge is hooked up in the right spot, so something is spiking my boost.
I would have thought connecting it to somewhere on the intake plenum is more appropriate, ie. after the throttle butterfly.
Posted: Sun Mar 12, 2017 1:07 pm
by roshmx5
Thank you so much, took off the t piece mod went back to original set up. Tested with boost gauge perfect 8psi no spiking.
Thanks Members you saved me.
