Sp owners with Boost Gauge
roshmx5
Postby roshmx5 » Sat Mar 11, 2017 5:29 pm
Hi members
Have hooked a boost gauge up and plumbed it straight into the manifold. I have done the t piece mod. My gauge sometimes goes up to 14psi as I am accelerating, especially in lower gears first and second.
Is this normal and have I connected boost gauge to the correct place to get a reading.
Have attached pictures
Mazda MX5 SP
Re: Sp owners with Boost Gauge
Postby NitroDann » Sat Mar 11, 2017 5:43 pm
You're going to have a bent rod or missing ring lands, Id take it easy if I were you.
roshmx5
Postby roshmx5 » Sat Mar 11, 2017 5:47 pm
Thanks Dan so the gauge is hooked up in the right spot, so something is spiking my boost.
Mazda MX5 SP
smy0003
Postby smy0003 » Sat Mar 11, 2017 6:33 pm
Agreed with Dann. Remove the MBC and check boost readings.
Instead of winding up the boost with the MBC, consider looking into ECU replacements to run more boost, more safety.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
roshmx5
Postby roshmx5 » Sat Mar 11, 2017 6:44 pm
I don't have a MBC only the t piece mod. And people say it may give you a 2 psi increase.
Mazda MX5 SP
smy0003
Postby smy0003 » Sat Mar 11, 2017 6:59 pm
Whatever it is, remove and check boost levels on your stock set-up.
roshmx5
Postby roshmx5 » Sat Mar 11, 2017 7:15 pm
Ok will look into it cheers.
Mazda MX5 SP
Nevyn72
Postby Nevyn72 » Sun Mar 12, 2017 10:55 am
roshmx5 wrote:Thanks Dan so the gauge is hooked up in the right spot, so something is spiking my boost.
I would have thought connecting it to somewhere on the intake plenum is more appropriate, ie. after the throttle butterfly.
roshmx5
Postby roshmx5 » Sun Mar 12, 2017 1:07 pm
Thank you so much, took off the t piece mod went back to original set up. Tested with boost gauge perfect 8psi no spiking.
Thanks Members you saved me.
Mazda MX5 SP
