Hi guys
What oil would you recommend for my NB SP.
thanks in advance.
NB SP oil recommendation
- roshmx5
Mazda MX5 SP
- pepejesus
Re: NB SP oil recommendation
Penrite Ten Tenths 'Racing 10' 10w40
2004 SE - stock ECU, stock engine, BEGi intake, FMIC, BC Racing 10/6, 15x8s, 225/45 NT-01s
Barbagallo long: 70.488
Barbagallo short: 58.999
- bear2230
Penrite HRP10 full synthetic 10W-50
- roshmx5
Thanks guys
Also has any one done the so called $2 mod with the t piece. If so what diameter vacuum line do I need and what are your thoughts did it make a good improvement.
Mazda MX5 SP
Congrats on the purchase of BULLITT's SP - you might like to add yourself to the SP owners list:
viewtopic.php?f=18&t=41971&start=210
- bigdog
- King of the kennel
Can't remember the vacuum hose size - 5mm maybe. Maybe mine went from 130 to 147 rwkw on the dyno with the mod, no real downside. That said mine used to ping terribly under load (before and after mid) so I went with low compression Wiseco pistons when I built the motor.
Sent from my iPhone using Tapatalk Pro
- roshmx5
Thanks big dog will do it this weekend have ordered parts. Great to see you had a Dyno result. That's a good gain for a simple mod and a cheap one at that.
Mazda MX5 SP
- roshmx5
Richard has helped me out with the parts I need. He has been a champ. It's 3/16 5mm like you said.
Mazda MX5 SP
