NA6 turbo oil feed location?
speed
Postby speed » Mon Dec 26, 2016 8:33 am
Should I go for option A?
This is where the MCM guys and other youtubers ran theirs from.
Or option B?
I could be wrong but I think this is where Dann runs his from?
Is this correct and is there any benefit of using one over the other?
Thanks.
smy0003
Re: NA6 turbo oil feed location?
Postby smy0003 » Mon Dec 26, 2016 8:51 am
Dann ran it from option A on my car. I think it's a case of 'If you've got it, use it.'
Sent from my LG-H815
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
speed
Re: RE: Re: NA6 turbo oil feed location?
Postby speed » Mon Dec 26, 2016 9:02 am
smy0003 wrote:Dann ran it from option A on my car. I think it's a case of 'If you've got it, use it.'
Thankyou!
Uno, I almost texted you to ask.
Your help is always appreciated :)
smy0003
Postby smy0003 » Tue Dec 27, 2016 9:58 am
Text away!
Postby NitroDann » Tue Dec 27, 2016 11:41 am
I use back of the head because I find it easiest to work on this way.
speed
Postby speed » Tue Dec 27, 2016 12:36 pm
NitroDann wrote:I use back of the head because I find it easiest to work on this way.
I'm guessing less oil spillage, if any.
Will have to see if I can get my hex bit in there :)
Is it possible to remove the sump whilst the engine is still bolted to the mounts?
(The car is already on a hoist.)
I ask as I have another sump with the turbo drain already fitted.
Also if I drill and tap my current sump, I'm going to need to go buy the stepped drill bit and a tap.
speed
Postby speed » Tue Dec 27, 2016 1:23 pm
I just watched a video on the sump replacement.
K frame out.
I thought I'd be able to lift the motor with a crane and have enough room to drop the pan.
Sounds like a real PITA.
Am going to go out and buy a drill bit and tap and just drill the bugger :D
