What inlet manifold - GTX/GTR engine?
Eeyore
Postby Eeyore » Fri Aug 12, 2016 11:02 am
When doing a GTX/GTR Familia engine conversion can you use the NA inlet manifold? I seem to recall the heads being similar. I have seen people cut and modify the FWD Familia manifolds but this seems less that ideal.
Kurt
1971 1300 Estate Deluxe
1973 1300 Wagon
1979 RX7
madjak
Re: What inlet manifold - GTX/GTR engine?
Postby madjak » Fri Aug 12, 2016 3:29 pm
If it's the BP-05 head which I think it is then yes the NA8 Intake will bolt right on.
project.r.racing
Postby project.r.racing » Sat Aug 13, 2016 7:00 am
NA8 will bolt straight on. The only different between a BP-05 and BP-26 head is some small bumps in the intake ports.
MrsB
Postby MrsB » Wed Sep 14, 2016 10:44 pm
Use the nb8b/c manifold flows the best rather than the na8/nb8a
project.r.racing
Postby project.r.racing » Sat Sep 17, 2016 4:11 pm
NB manifolds wont work as the flanges on the manifold are different.
cookie
Postby cookie » Thu Sep 29, 2016 11:41 pm
Intake is easily available. I found more expense in the oil pickup/pan. Not relevant to this question but something I went through. Also need to block off/ weld the heater core pipe thingo near the thermostat housing. I squashed and brazed mine. I have tried Un successfully to pull it out.
Sent from my SM-G920I using Tapatalk
Eeyore
Postby Eeyore » Sat Dec 10, 2016 8:52 am
What difficulties did you come across? Can't I just use an NA sump and pickup when doing the swap?
Kurt
1973 1300 Wagon
1979 RX7
