ebay braided oil and water lines and other bits
dzammit85
Postby dzammit85 » Sat Jun 11, 2016 12:42 pm
Hi, can anyone tell me if the oil and water lines are good from eBay, I'm also looking for the manifold flange plate and the t25 flange plates, I've been looking around through online retailers though can't find anything, can anyone recommend any sites to buy turbo parts, or any local retailers around Sydney
Thanks
Re: ebay braided oil and water lines and other bits
Postby NitroDann » Sat Jun 11, 2016 1:34 pm
What do you need exactly
dzammit85
Postby dzammit85 » Sat Jun 11, 2016 4:12 pm
Hi dan,
This is what I have so far
Garrett gt25
Intercooler plus piping
Air filter plus piping and heat shield
Blow off valve
Manual boost controller plus guage
The manifold and dump I'll be buying from you once I'm ready and most likely be using the stock heat shield with that also
So I need everything else, oil and water lines plus the bits to connect them to the turbo
Flange plates for the manifold and turbo, though I'm not sure if these are needed
And I'm not 100% sure if I'm missing anything here but if I am then I need that also
I'm also looking at an exhaust from the dump pipe back to match your dump pipe, if you sell the other stuff then would you be able to pm me a price on the manifold and dump, an exhaust from the dump back, and the other bits I need
Thanks David
dzammit85
Postby dzammit85 » Sat Jun 11, 2016 4:20 pm
Sorry I forgot to mention that I also have id1000 injectors so I want need them either
