Help: turbo and manifold fitment
smy0003
Postby smy0003 » Mon Mar 14, 2016 4:54 pm
Hi everyone.
Not long ago a bought a nitro dann turbo manifold (well it was sold to juffa as a dann manifold anyway).
Today I picked up a gt2554r, and I can't get them to fit together.
It's not that the flanges are wrong, there's half a mm in it, I think one of the manifold studs is very slightly out of plumb.
What's the best course of action here? Is it kosher to file out your turbos exhaust flange, assuming you can find something hard enough to file such a beast?
Thanks.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
pressure pack
Re: Help: turbo and manifold fitment
Postby pressure pack » Mon Mar 14, 2016 7:50 pm
run the next size drill through the 4 holes.
na8 turbo on nittos. w.p 106.8 smp south 102.4
Postby NitroDann » Mon Mar 14, 2016 8:41 pm
The flange should have been CNC drilled and should be fine although if someone since has chased the threads with a tap they may have tapped it at a slight angle, absolutely drill the 4 holes bigger, it usually drills really nicely and easily.
smy0003
Postby smy0003 » Mon Mar 14, 2016 8:54 pm
NitroDann wrote:The flange should have been CNC drilled and should be fine although if someone since has chased the threads with a tap they may have tapped it at a slight angle, absolutely drill the 4 holes bigger, it usually drills really nicely and easily.
Thanks Dann, exactly the person I need advice from.
Yep, looks like someone has tapped one of the studs very slightly out. Oh well.
Seems like drilling the exhaust housing is the way to go, don't know why I questioned it in hindsight; people have to drill it out to run 10mm studs anyway.
smy0003
Postby smy0003 » Thu Mar 17, 2016 9:45 am
Hey Dann,
Got the manifold machined because it had warped a bit, the guy said it was one of the best made manifolds he had seen. He said usually they're made out of cheap junk and are a pain to put straight, and he actually charged me less than the quote because it was so easy to work on.
Postby NitroDann » Thu Mar 17, 2016 9:55 am
Thats really nice to hear :)
Thankyou.
Users browsing this forum: No registered users and 80 guests
