Broken Air intake temp sensor
Jaxom_2
Postby Jaxom_2 » Wed Feb 24, 2016 4:05 pm
Hi all, I broke my aftermarket air intake temperature sensor and can't remember what one I used!!!!
It was one with known graph curve for entering into an adaptronic ecu.
it had a plastic/ceramic grid to protect the sensor the numbers and letters stamped on it are - ACR - 12V - 3
and also has 1801 stamped on it.
It also has a 2 pin plug
2002 with a Kraftwerks C30-74 Rotrex Kit zooom frick'n zooom
Re: Broken Air intake temp sensor
Postby 93_Clubman » Wed Feb 24, 2016 4:09 pm
Probably General Motors/ GM AIT sensor.
smy0003
Postby smy0003 » Wed Feb 24, 2016 4:50 pm
Yep, Adaptronic gives the values for the GM open element sensors on the forum.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Jaxom_2
Postby Jaxom_2 » Wed Feb 24, 2016 5:00 pm
Thanks for that, Adaptronic also sell the sensors.
I remembered the company in the US i purchased the original from - DIY AUTOTUNE,
Same info as Adaptronic.
Thanks again, just bought the sensor from Adaptronic
