Turbo exhaust heat shield fabricators? [BRIS]
NicTheMx5
Postby NicTheMx5 » Wed Feb 03, 2016 11:46 pm
Is there anyone in the Brisbane area who is handy with fabricating turbo exhaust manifold heat shields?
Before you ask, yes I've tried DIY but it hasn't turned out very well... EVERYTHING IS MELTING!
I'm running a TD05 Greddy kit (see pictures). It's all quite an awkward shape and lots of things are in the way (mainly heater hoses), hence my failure at self attempt.
NA6 TD05 :NA6:
d3ck5
Re: Turbo exhaust heat shield fabricators? [BRIS]
Postby d3ck5 » Thu Feb 04, 2016 7:19 am
firstly, get nopro washer bottle and totally remove that from the equation.
have you tried some gold heat tape on those hoses?
what about silicone hoses?
bear2230
Postby bear2230 » Fri Feb 05, 2016 8:23 pm
Heat shield material from Ebay and a Turbo blanket made a heap of difference on the white car.
Just a couple of bent brackets to support the cover. Now all the hoses aren't melting :D :D
http://www.ebay.com.au/itm/150871392886 ... EBIDX%3AIT
http://www.ebay.com.au/itm/turbo-muffle ... SwPe1UBwUs
Richard.
NicTheMx5
Postby NicTheMx5 » Sat Feb 06, 2016 4:21 pm
Ebay turbo blanket is holding up ok?
I've heard some pretty bad "fire" related things about even name brand turbo blankets, so I've just stayed away.
Also washer relocation kit is on its way in the mail!
NA6 TD05 :NA6:
NicTheMx5
Postby NicTheMx5 » Sun Feb 07, 2016 11:52 pm
NicTheMx5 wrote:Ebay turbo blanket is holding up ok?
Actually also keeping in mind this is a daily driver, so it wouldn't be every second weekend at the track sort of thing either.
So not sure how long they would last in this situation. Anyone have any advice or knowledge on the matter?
NA6 TD05 :NA6:
mr bender
Postby mr bender » Mon Mar 07, 2016 3:42 pm
I did make a cover up for that kit when it was on my car, it was made from ACL heat shield from super cheap.
Users browsing this forum: No registered users and 93 guests
