safe boost
Posted: Mon Nov 02, 2015 3:00 pm
by khanacross
hi guys/ girls ,my car is na6 ,fitted with t25/28 ,AVO manifold,rx8 injectors , megasqiurt pnp2, intercooled, 2.5in exhaust high flow cat ,magnaflow muffler .the engine itself standard 1600cc ,im currently running 5psi boost ... my question is how much boost is recommended ? whats everyone running ? ,my car is daily driver ,not chasing outright power just safe reliable tune .. thanks in advance
Re: safe boost
Posted: Mon Nov 02, 2015 3:28 pm
by NitroDann
The short answer is that boost does not equal broken parts its more complicated than that. If youa re going to run one boost pressure across all rpm and conditions, 12psi.
Re: safe boost
Posted: Mon Nov 02, 2015 3:41 pm
by khanacross
thank you dann
Re: safe boost
Posted: Tue Nov 03, 2015 11:18 am
by khanacross
I intend on running progressive boost through the rev range ,start low boost make it linear through revs building up to max boost , that's why I asked what was average max boost to run .. thanks heaps
Re: safe boost
Posted: Tue Nov 03, 2015 11:43 am
by NitroDann
12 at 4000, 16-18 at redline depending on the turbo/setup.
Re: safe boost
Posted: Tue Nov 03, 2015 2:52 pm
by khanacross
thanks dann , really appreciate your replies .
Re: safe boost
Posted: Tue Jan 19, 2016 6:23 pm
by MattR
So the answer you are looking for is not:
Add boost until it goes bang and then just wind it back a little on the next motor????
Because if it isn't, I haven't got anything to add, just bored at work......
Re: safe boost
Posted: Wed Jan 20, 2016 7:23 am
by lightyear
From my reading 12psi is max for a track car, and you can go more on a road car. I run 12 flat.
