tdo4l /tf035 turbo
- Learner Driver
tdo4l /tf035 turbo
hi guys , does anyone run a TF035 turbo on there NA6 ? what are your thoughts ? good or bad , my thoughts are ,it should spool up quick ,be fun low boost daily driver ,, appreciated your input ,,thanks
Re: tdo4l /tf035 turbo
I'm no turbo expert but the TD04 is the larger turbo right? I have one (albeit slightly modified) off a T5 Volvo. On my NB it produces 163rwkW on 7psi, very smooth delivery with practically no lag.
I can't imagine a smaller turbo though...I assume it will practically be on boost all the time. Check with Nitro Dann - I recall him fitting a car with a really tiny turbo just for laughs.
- Learner Driver
thanks for reply
- Learner Driver
anybody here use the tf035 ? turbo is off a Subaru forrester / also on 2.8diesel Mitsubishi .. I do believe its the same as the mighty car mods guys used on there white NA .. could be wrong though
- Vehicle: 10AE - Turbo
"On my NB it produces 163rwkW on 7psi, very smooth delivery with practically no lag"
Interetsed in how you managed that Apu with 7psi?
10AE
WP 1:04.7 SMSP GP 1:43.0 South 1:00.8 North 1:09.8
Nitro Dann tubular manifold, Volvo TD04 turbo with WRX compressor wheel.
a lot of reading here about td04 compressor flow maps ken.may be usefull.
http://www.stealth316.com/2-3s-compflowmaps.htm
Mick
Mick
- NitroDann
Apu also has water/methanol injection, and that reading was on the Mania dyno which is known for being a little enthusiastic, regardless it has an efficient setup that hauls arse.
True...but water-meth produces an extra 13kw, so it reads 176rwkW on the Mania dyno.
Speaking of which...would be good to organise a dyno day some time!
Users browsing this forum: No registered users and 74 guests
