42mm rad but no change in coolant temp?
Hey, I have a nb8b with added t25 turbo & IC, otherwise std.
The std radiator left the coolant temps between 95 and 100, no matter how easy I drive or how cold it is outside. Light throttle driving sees the fans on always.
I have installed a 42mm radiator and it has made zero difference. I have sat car running on steep incline, topped up overflow, let it cooled rerun...no change, sit 95-100 with fans on.
What have other people done to get air to the radiator or other suggestions, I thought the bigger rad would really change the hot running motor. Am I missing something.
Cheers.
Cheers.
3 different turbo NB's in this single Garage Thread...viewtopic.php?f=57&t=67687
- Vehicle: ND - RF
Re: 42mm rad but no change in coolant temp?
Not all aftermarket radiators are created equal.....
What did you use?
How are you measuring the temperature and where from?
What did you use?
Is your waterpump and thermostat ok
Rob
Yes, its a ebay chinarad. Measuring from the laptop with tunerstudio (megasquirt car)
Burped some more air from the system this am and was able to add heaps of water, holds 92deg w out fans so its better than before.
Anyone recommend a high flow or low temp thermostat?
http://www.ebay.com.au/itm/TRIDON-HIGH- ... 19e7b00cc4
Thanks for the input.
- NitroDann
low temp thermostat wont help if the one you have is lower than your coolant temp already. You will just be changing one thermostat that sits fully open for another one.
A cooler engine temp MAY produce more HP, but fuel economy/emissions will worsen. Just remember thermostats only control minimum temperature and just because you put a thermostat will a less opening temperature or a high flow does not imply you will get an overall temperature decrease.
But... if the engine runs too cool, thermal efficiency is lost, power is reduced and parts wear out quicker.
I'm using that one. They used to be sold by MX5Mania. They're pretty good.IanR wrote:Anyone recommend a high flow or low temp thermostat?
As others said, don't go low temp, it buggers up the mixtures. High flow is good though for a modded or tracked motor.
This is data from the recent JapNats at Queensland Raceway.
Air Intake Temp is down the left and speed across the top. The MAX water temp is in the body of the table. The car is running an OEM thermostat, PWR water/oil combo.
Water Temp by Eipeip, on Flickr
High flow in the low 90 deg range is what makes sense from the info so far. I don't want it to run colder than 90 for efficiency but need but more ability to dump heat than Std setup.
- NitroDann
High temp stat won't help on your ecu equipped car
Magpie wrote:This is data from the recent JapNats at Queensland Raceway.
Air Intake Temp is down the left and speed across the top. The MAX water temp is in the body of the table. The car is running an OEM thermostat, PWR water/oil combo.Water Temp by Eipeip, on Flickr
looks pretty stable. good setup then.
NitroDann wrote:low temp thermostat wont help
NitroDann wrote:High temp stat won't help on your ecu equipped car
You like the oem one for the nb?
- beavis
- Vehicle: NB8B - Turbo
beavis wrote:http://www.miataturbo.net/race-prep-75/miata-cooling-system-thread-79930/
That's inserting reasonable and informed commentary into the thread, Brendan. Forum rules ban that.
