Turbo auto na
Coote_00
Turbo auto na
Postby Coote_00 » Wed Mar 11, 2015 11:26 pm
Hi all,
Wanted to know if I would run into many problems installing a turbo on a auto na enuos roadster. Any help would be great cheers.
Re: Turbo auto na
Postby NitroDann » Thu Mar 12, 2015 9:06 am
Do it!
That would be a really cool daily cruiser. Yes the auto gearboxes are known to be very tough, the only thing to look into is whether the gearbox needs the OEM ecu at all, if not (90% sure its a oldschool dumb slushbox with no extra brains that arent mechanical and therefore doesnt have electronics for it) just turbo it.
Re: Turbo auto na
Postby 93_Clubman » Thu Mar 12, 2015 9:41 am
Magpie on this forum has extensively modded his formerly auto NA6 - worth a PM:
memberlist.php?mode=viewprofile&u=8059
Re: Turbo auto na
Postby hks_kansei » Thu Mar 12, 2015 9:47 am
Turbos are great on Autos in general.
I have no idea why people convert Toyota Chaser and MArk2 to Manual, the auto is just so perfectly suited to the car and the power delivery.
sailaholic
Re: Turbo auto na
Postby sailaholic » Thu Mar 12, 2015 10:28 am
For hectic skid drifts yo.
noobee
Re: Turbo auto na
Postby noobee » Thu Mar 12, 2015 10:37 am
i was told the mx5 auto is the same as the jatco auto in vl commodores,if so it will be more than capable.Ive seen those things take a lot of abuse in VL's and just keep going.
Mick
Re: Turbo auto na
Postby hks_kansei » Thu Mar 12, 2015 11:02 am
Autos in general seem to be able to cope with more grunt than an equivalent manual.
WHen you think about it, the fact it uses a torque converter means that it softens the sudden thump of power that dumping the clutch gives.
The main thing that kills them is heat, so you may want to look into a trans cooler if it gets a bit hot (shouldn't be expensive, they use them all the time on tow cars)
I'd be looking at putting in a 1.8 diff too, since with a turbo auto you will do burnouts. You won't be able to resist.
olboy
Re: Turbo auto na
Postby olboy » Thu Mar 12, 2015 4:45 pm
We have a auto turbo na that we built out of bits
We use it for dirt motorkanas
there was no mechanical problems
only thing to watch out for is the box is a bit bigger and the exhaust pipe runs very close to it
not a problem if you use a custom pipe
Biggest problem has been the computer
I think the original cars use a slightly different main computer and an extra one for the box and they talk to each other
We are using a EMS with a home made extra one to work the box
It's alright for what we are doing with it , we only use 1st and 2nd
I don't know how you would go with a road car , you should run an aftermarket computer but I don't know of any that will work the box
I have a friend who is a great with computers and he's been having trouble
I think we worked out the box wasn't a VL box but the same as an early RX7
In short the mechanical side of the conversion is easy, it's the electronics that are hard
Maybe you should find someone that has put an aftermarket computer on an auto car turbo or otherwise
olboy
Coote_00
Re: Turbo auto na
Postby Coote_00 » Thu Mar 12, 2015 10:34 pm
Thanks for all the info guys.
Is there anyway to tell if box needs ecu?
I thought early 1.6 didn't have ecu for box
Mr nanotech
Re: Turbo auto na
Postby Mr nanotech » Fri Mar 13, 2015 12:48 am
hks_kansei wrote:Turbos are great on Autos in general.
Isn't the jzx100 auto much taller though?
Re: Turbo auto na
Postby 93_Clubman » Fri Mar 13, 2015 12:28 pm
Coote_00 wrote:Is there anyway to tell if box needs ecu?
MarkM-UK 25th June 2005 08:45:
"Am and have been running a 91 auto with FM link [ECU], manual cams, custom 4:1 header, quad zausts and JRSC for the last two years (now with smaller pulley) at about 8PSI.
No real problems with the auto box which as well as being used in the old 626 was also used in London taxi's until about 97! So it can handle a lot more torque than our little roadster can throw at it.
Jackson/Moss do a auto transmission valve which delays 'change-up' by about 8 MPH
which you should be able to use. Also you should be able to upgrade your cams as I've done...if your ECU can handle it.
One real problem you have with a 1993+ auto is that there is a link between the ECU and the transmission so more difficult to modify."
http://forum.miata.net/vb/printthread.php?t=137696
