Turbo fitment nb8b
MXO00V
Turbo fitment nb8b
Postby MXO00V » Sun Jan 18, 2015 6:01 pm
hi there
I have a nb8b with a gt2560 on a low mount manifold by suli from pure fabrications
I am having issues fitting it
the intake to the turbo is just touching the coolant hose on the side of the block
What have people done to get a bit more clearance?
Sent from my SM-N910G using Tapatalk
MXO00V
Re: Turbo fitment nb8b
Postby MXO00V » Sun Jan 18, 2015 8:08 pm
MXO00V
Postby MXO00V » Sun Jan 18, 2015 8:10 pm
Was thinking a 30mm right angle then alloy pipe to join to stock coolant hose
Not sure if it will work
jp928
Postby jp928 » Tue Mar 10, 2015 10:39 am
If its not going to chafe (no relative movement between the two parts) I wouldnt worry too much about the cold side. Turn the clip so it cant rub on anything. Most worries should be about the hot side.
jp 92na6, Clubby with a Turbo NA8.
Postby NitroDann » Tue Mar 10, 2015 11:18 am
Forget it its fine
