Budget NA6 supercharge build
Posted: Sun Dec 28, 2014 9:04 am
Hi all for shits and giggles I installed a supercharger that I had onto my NA6
I believe it is an M45 off a cooper s. I picked it up with all associates brackets etc.
I was going to wait until I had a new engine (current one had SNC issue), fuel reg, intercooler, ecu, injectors etc etc, but since the motor was on its way out I thought why not just bolt it on and see what happens
Here was the result.....
http://youtu.be/6zkXxmzGiVI
To get it to work I took the air flow sensor off the airbox and just joined it to the second throttle body on the supercharger
When I was playing around I found that moving both the throttle bodies together seemed to work better...... But ATM the throttle body is just rigged open.
TBH I'm scared to drive it.......
Noob question for the wiser heads...... Will it go bang?
Can I actually get this to run and drive on the stock ecu (I know that I won't get te best out of the supercharger)?
How do I get the twin throttle bodies to work together?
Any help appreciated.
