Modifying an SE
Posted: Fri Dec 26, 2014 5:32 pm
I did a bit of a search but got a few red herrings so I hope you don't mind me creating a thread.
I'm looking at getting an SE (just comparing it to an nc3), and I wonder what nuggets of wisdom you can offer on modifying it to a nice power output (nothing crazy).
I had my s15 built and tuned to 300rwhp so I have some basic knowledge on mechanics and modifying cars and I'm not afraid to spend some cash. What I don't want is a shoddy or unreliable car, which in my experience is often the case with turbos.
I see the mx5 mania stage 1 kit (2.5" exhaust, air pod, big front mount fitted for $2800) bumps power from 121kw (flywheel) to 145rwkw. This seems quite significant to me so I'm guessing the engine is very restricted from factory.
I read around a little bit and apparently the stock ecu has a boost cut over 10psi, and the fuel system maxes out quite easily. Also read that the blow off valve isn't much chop? A solid intake pipe (on the plenum?) seems to be popular too.
In my experience fitting a big front mount took away throttle response and messed with the tune on my s15, almost enough to warrant a retune.
If I was to skip the cooler and just go with a nice exhaust, pod + solid intake + bov, would I have decent performance?
And any thought on reliability of this car or comparison with an nc?
