Question for the SP owners here
498
Postby 498 » Wed Dec 03, 2014 8:06 pm
Hi everyone,
The carbon fibre airbox on my SP has lost half its clips :cry: I've heard they aren't great and it's a common issue.
Did you repair or replace? What did you find and how'd you go about it?
bear2230
Re: Question for the SP owners here
Postby bear2230 » Thu Dec 04, 2014 11:46 pm
Yeah those little clips are a real sh*t. Mine are pretty good but I know others have bought different types of aftermarket toggle clips and either screwed or riveted them on.
You can't replace the air box as there just aren't any to replace with. The last one I heard of sold for around $1000 and you won't be buying that as a spare. I know I tried. Its not for sale.
Richard.
498
Postby 498 » Fri Dec 05, 2014 8:28 am
Cheers mate...yeah I realise I won't be finding an OEM replacement and frankly, I'm sure there are better aftermarket options. That said, I'd prefer repair over replace because it's a 1 in 100 piece.
Aftermarket toggle clips though...that's an interesting prospect. I've got some Googling to do!
Locutus
Postby Locutus » Fri Dec 05, 2014 7:52 pm
Yeah the clips aren't great, but the mounting of the airbox is to blame. The flex joint is a bit of a joke and the spring mount on the bottom half of the airbox is too rigid.
Has anybody come up with a fix?
bigdog
King of the kennel
Postby bigdog » Fri Dec 05, 2014 8:44 pm
My filter seals fine with only half the clips. I have contemplated fitting better clips, but it's a low priority when it all works...
498
Postby 498 » Fri Dec 05, 2014 9:30 pm
I may have found a suitable replacement clip in stainless.
I'll do some measurements and report back.
NASilverStone
Vehicle: ND - Supercharged
Postby NASilverStone » Sat Dec 06, 2014 8:00 pm
i am missing one and the rest have no tension on them. I look forward to hearing what you have found. Cheers NAS
2016 BMW X1 xDrive 25i
BULLITT
Postby BULLITT » Fri Dec 19, 2014 9:43 am
Hi Fellow SP Owners,
After much searching I found a source for the original clips/latches:
RGA Fastners (in Sydney) (Phone: 02 9560 7266)
Part No: 97-30-160-12 Southcorp Small Over Centre Latch S/S
They are $8.50 each and delivery is $8.00.
Regards,
Simon
BULLITT
(2021 Polymetal Grey ND2 1.5 Roadster
NASilverStone
Postby NASilverStone » Fri Dec 19, 2014 9:07 pm
Thanks for sharing the information Bullitt, Cheers NAS
Garry
Postby Garry » Sat Dec 20, 2014 9:58 pm
Thanks Bullitt. I don't need any at the moment but handy to know
erskimo
Postby erskimo » Mon Jan 05, 2015 11:59 am
The clips do leave a bit to be desired (more over center would be great) im lucky I have not lost one (she only did 5, 000 kays and that was a trip from Mackay for the year) I cleaned the area around the clip and placed a piece of 100 mph tape over the top, it the same principle as 1/4 turn fasteners on many motor bikes, yes the 0.10 grams for weight could become a problem................................ :D
baaaRINGGG dadinggg ding ding
bear2230
Postby bear2230 » Mon Jan 05, 2015 1:45 pm
Hi erskimo, welcome.
Would you like to add your name to the SP owners list? and give us some details about your SP please.
viewtopic.php?f=18&t=41971&hilit=Sp&start=120
Richard.
erskimo
Postby erskimo » Tue Jan 06, 2015 10:44 am
All done Richard
Geordie
Postby Geordie » Wed Jan 21, 2015 5:07 pm
BULLITT wrote:Hi Fellow SP Owners,
Regards,
Simon
THanks I need a new one
I also found that using shrink rubber on them ( the stuff you fire your blow torch at) made them stick much better probably by giving them a bit of flex.
Regards
Geordie
Owner of Puffed Rice (pure white SP), recently translocated from Brisbane
498
Postby 498 » Tue Mar 17, 2015 3:40 pm
Regards,
Simon
I'm glad someone else had some luck...the ones I'd found were just fractionally out of whack...just enough that I wasn't satisfied with them.
I emailed RGA and their minimum order is 10 pieces. Anyone interested in joining me for a group buy?
