It consists of the following:
- SC12 Supercharger from a MR2 AW11
- Hot Side - Low mounting brackets to suit
- All piping (non-intercooled)
- Haltech E6K ECU and complete loom (Plug and play)
- there might be some more stuff but im not 100%
So i have a few questions i've searched both here and on Miataturbo.net and haven't received the answers to all my questions.
So hopefully you guys can help
1. Injectors - On the wiki it lists several injectors that can be used. My question is this besides the familia GTR/GTX are there any drop in injectors that i can use that are higher than 360cc where i don't have to add resistors or in anyway modify to get them to fit.
Essentially i want to take out the old, install the new reconnect them and done.
2. Fuel Pressure Reg - Should i get one and if so which would be the best bang for buck option. The reason i ask is that the car is now 20 years old and i plan on replacing with a walbro unit (as it is the most common and seems to be the simplest to install)
3. COPS - Should i bother going through and modding the ignitor and will it make much of a difference at 6 - 10psi?
4. Intercooler - I've spoken to a few people that suggested WMI but im not keen on this idea i was considering a small intercooler, like those used on the S13/VR4/R32 GTST - one of the small sidemounts would this be effective enough?
Thank you for your time and again if this has been covered before or if anyone else is using a SC12 please link me
