ECU & Dyno tuning for an AVO turbo on a 96 NA8
jp928
Postby jp928 » Sun Aug 31, 2014 12:06 pm
We are turboing a 96 engine/drivetrain for a Clubman (lotus 7 replica). We have all the hardware, but are having a lot of trouble finding somebody who can supply a piggy back ECU for it, install and tune. AVO seem to have lost (or never had) how to connect their own ECU to this model of ECU - 3 connectors, one vacant socket.
Mate has a 94 NA8, to which he has fitted a Rotrex blower, with an Xede controlled mixture and ignition (2 maps). This has been totally reliable over 3 years and 10k kms. This is running a 5th injector, which I Know is regarded as crude, but it works, fuel economy is not an issue, and it has not required upgrading the stock injectors or the pump or pressure regulator. It was fitted at Chiptorque in QLD .
One local melbourne operator says he doesnt have time to do an install, he just tunes.
Can anybody in Melb please recommend somebody here who knows MX5s, and can advise on an ECU, install and dyno tune? Prefer to keep the stock ECU and piggy back unless we can be persuaded otherwise.
thanks
jp
Re: ECU & Dyno tuning for an AVO turbo on a 96 NA8
Postby 93_Clubman » Mon Sep 01, 2014 12:32 pm
96-97 NA8 used a 16 bit ECU as opposed to the 8 bit ECU for 93-95 NA8, ie three female connectors on the ECU (plus one vacant), as opposed to two.
Contact Dan or Daz @ Road Track Rally, 10 Fiveways Blvd, Keysborough, 9798 5944, <http://www.roadtrackrally.com.au/>;
And Dean @ Motorsports Essentials, 6 Macbeth St, Braeside, 9587 0079, <www.motorsportessentials.com.au> might be able to assist;
Gerald & Chaz @ Mammi Motors, 10 Industrial Drv, Somerville, 5977 7973, <http://www.mammimotors.repcoservice.net/> are also great with MX5s generally.
Users browsing this forum: No registered users and 259 guests
