external map sensor? plis more qna.
cookie
Postby cookie » Fri Aug 08, 2014 12:35 pm
Sorry. I'll probably ask alot of dumb questions. Firstly what's the purpose on a haltec sport 1000 of this device. It looks like a map sensor. Vacuum lines go from intake manifold - tee - internal map sensor, fpr and this device.
Thought it might have been a Mac valve but only one connection. Has power, ground and signal wire by the looks of it.
The ecu has a plug in harness. Are adm and jdm the same engine loom/chassis loom at all? the plan is to remove the turbo setup off this car, return to NA for cheap fun for my dad. - eventually boosting the Malibu. I just would like to learn as much as possible from this as i can before ripping it out.
This looks ghetto. Is this normal install practice?
(afm)
Re: external map sensor? plis more qna.
Postby NitroDann » Fri Aug 08, 2014 2:01 pm
Does it have a boost guage?
cookie
Postby cookie » Fri Aug 08, 2014 4:58 pm
NitroDann wrote:Does it have a boost guage?
A mechanical one, yes.
