Most reliable setup for NA
- angusis2fast4u
Okay so i'm planning to turbocharge my NA6 in two years time - enough time to do all the turbo supporting stuf like brakes, diff, transmission etc... (and p plates) i would want to make the car as reliable as possible and in the future put down as much power as possible, would i be best off buying a nb8 engine and building (forge turbo etc) it out of the car off to the side for the next two years, or turboing the current engine.
currently i have thought a bit about it.
Advantages of nb8:
1. less off road time for the car (engine gets dropped in when built. obviously i would need to do the whole wiring loom.
2. potential for power (more torque)
3. reliability, some 1.8's came turbo'd so more reliable
Advantages of 1.6:
1. money (cheaper)
2. don't have to re wire whole car.
Anyways they are just the obvious advantages of each, what do you guys think?
Advantages of nb8:
Advantages of 1.6:
1. money (cheaper)
~Angus
2001 Silver NB8B
Past: Grey 1990 Eunos Roadster
2001 Silver NB8B
Re: Most reliable setup for NA
B6 was the original turbo - Mazda 323 gtr.
NBb engine I assume you mean (variable timing) has the better sump with the crank girdle and better factory oil pump.
Absolutely do the engine out of the car either way. If you want big hp forged, super reliable etc, that's going to take a few weeks min to get built.
Also by the time your done an extra few hundred on a spare engine isn't going to change to budget much.
- NitroDann
angusis2fast4u wrote:Okay so i'm planning to turbocharge my NA6 in two years time - enough time to do all the turbo supporting stuf like brakes, diff, transmission etc... (and p plates) i would want to make the car as reliable as possible and in the future put down as much power as possible, would i be best off buying a nb8 engine and building (forge turbo etc) it out of the car off to the side for the next two years, or turboing the current engine.
Advantages of nb8:
Its not as hard as you think to put in a 1.8L especially seeing as you are going to use aftermarket management anyway.
It will spool the turbo a little bit earlier and make really big power easier but at 150-200rwkw the difference is minimal.
False, the factory turbo engines are for all intents and purposes identical to the n/a engines. The weak poitn in all B6 and BP engines is the rods and they all share the same part number, so on a stock engine power handling is identical regardless and any built engine can take way more power than you can possibly use.
Advantages of 1.6:
1. money (cheaper)
Maybe, maybe not. I guess a 1.8 engine itself will cost a few hundred bucks but thats all.
See above, with aftermarket management its really a non issue.
What goals for the car. The easiest question to ask is, what will you do with it, and who do you want to keep up with in a straight line?
Read Charlie91's thread and learn
Or have a chat with Jason from MX5 Plus they maybe putting a hairdryer on their track car.
- angusis2fast4u
NitroDann wrote:angusis2fast4u wrote:Okay so i'm planning to turbocharge my NA6 in two years time - enough time to do all the turbo supporting stuf like brakes, diff, transmission etc... (and p plates) i would want to make the car as reliable as possible and in the future put down as much power as possible, would i be best off buying a nb8 engine and building (forge turbo etc) it out of the car off to the side for the next two years, or turboing the current engine.
Advantages of nb8:
Advantages of 1.6:
1. money (cheaper)
Plan is for about 350rwkw-400rwkw
~Angus
2001 Silver NB8B
2001 Silver NB8B
- NitroDann
Are you serious?
Lol, That's going mega expensive to make reliable. And even then reliable with depend on your view.
Plan is for about 150rwkw-200rwkw
i fixed it for you.
Don't get caught up chasing numbers!
Jesus
- Vehicle: ND - Turbo
- angusis2fast4u
M1474 wrote:LS1
Definitely the route i wanted to go in the beginning, want to keep it street legal though so either engine swap something and lose a heap of reliability, or max out the engine again losing reliability.
~Angus
2001 Silver NB8B
2001 Silver NB8B
- Black_Penguin
There is no way in hell you could make 350kw streetable let alone legal. Even if you managed to get traction you are just going to break drive line parts.
Sent from my HTC One XL using Tapatalk
Keep the forum updated and post the dyno run, looking forward to seeing this build.
- NitroDann
You could, I have built setups that are very streetable which could make near 350rwkw, and there are setups in the states that are capable of this and still drive okay.
You wouldnt use a 1.6 though youd use a VVT engine.
Hell pats 250rwkw NA6 is fast enough to scare the sh*t out of even 90% of modified turbo street guys but it drives fantastically, its very torquey and tractable.
For 300rwkw you would run an EFR6758 on a 1.9L VVT engine, and you will make good torque and it wont really be laggy. On the street this could be reliable diff and gearbox wise with SE diff and 6 speed, but you probably would want to go to an rx7 or z32 box.
how much money do you want to spend?
and are you going to do the work yourself?
