SE fitting boost gauge
WASP
Postby WASP » Mon Mar 10, 2014 2:29 pm
Hi I am going to fit a boost gauge to my SE, a naïve question, what is the best way to fit the hose through the firewall and into the cab. I am loath to start drilling.
Steven
Re: SE fitting boost gauge
Postby Lokiel » Mon Mar 10, 2014 3:09 pm
In the engine bay, if you look below the black brake booster housing (on the driver side firewall), you'll see a rubber grommit with some wiring going into it. You can push the vacuum hose through that, no drilling required.
WASP
Postby WASP » Mon Mar 10, 2014 5:53 pm
Lokiel wrote:In the engine bay, if you look below the black brake booster housing (on the driver side firewall), you'll see a rubber grommit with some wiring going into it. You can push the vacuum hose through that, no drilling required.
Thank you
