ticking noise
Posted: Sat Feb 08, 2014 5:13 am
by mrchoosy
Hello,
I have an 1,6 NA engine. Installed the begi S3 turbokit with walbro fuel pump,OEM fuelrail and RX8 450cc denso injectors on a MS2
After installing this, I've heard a annoying ticking. The noise is coming thru the floor on the passengers side. It drives me nuts...
I want to get rid of this noise inside the car
All injectors are working simultaneous and are producing the normal operating tick.
BUT: this tick is amplified by the fuel rail and follows the fuel lines. I can even hear the tick at the fuel filter (which is also new).
What is the solution for this problem?anyone who has this ticking noise too?
thanks
Re: ticking noise
Posted: Sat Feb 08, 2014 8:48 am
by NitroDann
You sure it isnt an exhaust leak?
Re: ticking noise
Posted: Sat Feb 08, 2014 10:29 am
by mrchoosy
1000% sure
Re: ticking noise
Posted: Sat Feb 08, 2014 1:54 pm
by chops
not a fuel pump noise?
Re: ticking noise
Posted: Sat Feb 08, 2014 2:43 pm
by sailaholic
Walbro pumps are known to be a bit noisy
Re: ticking noise
Posted: Sun Feb 09, 2014 7:18 am
by mrchoosy
the tick is going faster as the revs are going up. the fuel pump is louder indeed, but a fuel pump makes a more constant (non ticking) noise I think.
Re: ticking noise
Posted: Sun Feb 09, 2014 5:59 pm
by NitroDann
If its not an exhaut leak then it;s the injectors, and thats just what injectors do.
Re: ticking noise
Posted: Sun Feb 09, 2014 11:37 pm
by mrchoosy
thanks for the reply
I know they make a typical ticking noise and this is the normal operating sound.
The problem is the loud ticking noise inside the car. I have compared this with 3 other cars with the same engine and injecors, also turbo modified. In the other cars, I've noticed the same tick noise, but barely hearable inside.
Mine is ticking loud inside (like a hydraulic lifter loud)
Again, engine is in perfect shape, no leaks, no HLA problems, oil new, rods ok
I can hear clearly the same tick at the injectors, fuel rail and even on the fuel lines under the car with my stethoscope.
So, I'm sure that I found the cause of the noise, but I don't know how to fix this
When you're listening in and around the engine bay, it's almost not hearable...
Re: ticking noise
Posted: Mon Feb 10, 2014 6:59 am
by Nevyn72
Check the length of the fuel lines to see if any of the spacers are missing or out of alignment. If the lines are contacting part of the bodywork/chassis then this may be transmitting and/or amplifying the sound.... You could also try packing some dense, thin foam between the fuel lines and anything they come into contact with. Don't know if it'll make any difference but could be worth a try.
Re: ticking noise
Posted: Mon Feb 10, 2014 7:46 am
by mrchoosy
thanks, I'll give it a try
good thinking!
Re: ticking noise
Posted: Sun Feb 16, 2014 4:36 am
by mrchoosy
after further diagnose it seems to be the Walbro fuel pump or the OEM FPR who can't handle the high pressure.
When I pinch of the fuel supply to the rail with a plier , the noise goes away.
The fuel pump is a walbro 255. I've installed the OEM fuel pump back and the noise went away...
So fuel pressure is to high for OEM FPR? anybody wih the same experience? solutions?
thanks
Re: ticking noise
Posted: Sun Feb 16, 2014 9:04 am
by bear2230
I have a Walbro as well but mine makes a humming noise. It annoys the sh*t out of me.
Unfortunately its the price you have to pay for more fuel and the alternative is holes in your block.
Richard.
Re: ticking noise
Posted: Sun Feb 16, 2014 9:38 am
by sailaholic
Walbro are known to be a noisy pump. Maybe look at other options Richard.
Re: ticking noise
Posted: Sun Feb 16, 2014 10:08 am
by bear2230
At the time it was what my Haltech guy recommended but happy to hear if you have any alternatives.
I will ask my new tuner as well as the guy that installed the Haltech also bent 1 and 4 conrods and then said sorry man.
sailaholic wrote:Walbro are known to be a noisy pump. Maybe look at other options Richard.
Re: ticking noise
Posted: Sun Feb 16, 2014 11:17 pm
by mrchoosy
The problem is not the humming noise...
The walbro 255 fuel pressure is to high, or the OEM FPR is to weak for the Walbro pump. (changed with other OEM FPR, same results)
