Final Turbo R&D + Leap of Faith?
Posted: Sat Oct 19, 2013 5:58 pm
First off, would like to say that I love my little na6 mx-5, its a great car and is a ton of fun, but it just feels like there is something missing, it just may need a bit more oomph.
Now, I have never been one to chase massive power figures, or mod something to the point where it is just not comfortable or practical for everyday use, but there are a few things that i am going to try and change over the coming months.
One of these things is the possibility of a small turbo setup. Inspired (Like im sure any were) by NitroDann's turbo for under $2000, I started doing research into wear and tear, reliability, and every day usability.
This proposed setup increases almost 50% in power and (possibly more) in torque, (which provides the most strain on mechanical components.) Taking this into account I have figured in clutch, diff (In the future, as this 'small' increase in power/torque should be fine for the time being, considering no track work) injectors, and a few other necessity's for a swap like this, ontop of the 'included basics'. Because this will never be aimed to be a 300whp monster, keeping things within budget, and still being safe shouldn't be too hard.
So to begin finalizing my R&D I have a few questions:
From all that I can gather, running a stock TD04 on wastegate pressure (7psi-9psi depending on where you read) without an inter-cooler is fine, safe, and reliable as long as you can keep as much heat away from the system as possible. People have run these on other cars (but not as many on mx-5's as I can gather) without the I/C, can anyone give me any heads up on drive-ability, and what their opinions as a daily would be?
Understanding what needs to go into doing a conversion, what can people who have Turbo mx-5's or even S/C mx-5s say to everyday comfort and reliability, keeping in mind this will likely be a lot more simple in design than a $5k+ conversion.
And lastly, do you think it is worth it, in your opinion, from having been in/driving/owning one do you think the effort is worth the result?
Some people I have talked to disliked modifying their na6-na8 preferring it to be stock over modified however, all of them did own other higher performance vehicles, so they may have wanted it (Mx-5) for a different purpose.
What do YOU think? would you rather your car was NA again? or does the increase in performance make up for the shortcomings?
I am very curious to know what you think about your Turbo 5, or about them in general. I'm just trying to see if making the leap of faith is worth it, especially for a system that does not change the OEM feel too much
Ive tried to do as much searching and research as possible, so this is the stage where i want to see other peoples opinions, however any links to forums/posts/comments would be great as I will take all the info I can get right now!
I have read about legalities, and issues that people have had over the forums.
And this guy who was looking into it, but at this stage an AVO $6000 job, is both too expensive, and over the top compared to the modest install that I am looking at, aswell as the tuning of the n/a engine is not exactly possible as i reckon most things that could be done have already been done:
viewtopic.php?f=81&t=59812
NitroDann's under $2k Thread
viewtopic.php?f=81&t=58863
Regards
Rhys
Regards
Rhys
